Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 03-17-2020, 01:16 PM
WinstonDeath WinstonDeath is offline
Default Pro Tools gets stuck in Scrub/Shuttle
This issue has been present for a few years it seems, mainly when connected to a EuCon or Icon control surface. The FFWD and RWD buttons get stuck lit up, and the transport status at the bottom left of the edit window displays either scrub or shuttle despite pro tools not actually being in that mode. The scrubber tool is not selected. Only a reboot seems to break this loop.
Anyone else?
Old 03-17-2020, 01:23 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Pro Tools gets stuck in Scrub/Shuttle
Maybe if you told a little about system specs first
Janne
Old 03-17-2020, 01:39 PM
Sorry, thought you’d see my bio info in the post. Also it doesn’t really matter since it’s happened on every version of PT and with every surface I’ve used in the last 6 years, but today I’m on:
Pro Tools Ultimate 2019.12 macOS 10.14.6, EuCon Workstation 2019.12, S6 M40
Old 03-17-2020, 01:40 PM
JFreak's Avatar
Just checking that you have compatible software. Now someone with EUCON may jump in knowing it is not a compatibility issue
Janne
Old 03-17-2020, 01:44 PM
Yeah every system I use is extensively researched for compatibility, both my home system and at the studio. I wouldn’t want to waste anyone’s time with incorrectly set up rigs on here.
Old 03-18-2020, 08:24 AM
its2loud its2loud is offline
This sounds like shuttle lock mode. What happens when you press the space bar and how does it get into that mode in the first place?
Old 03-19-2020, 06:40 AM
Space bar starts and stops transport as usual. All the GUI signs for shuttle lock are there, it’s just not actually in shuttle lock. You can toggle between the transport status in the bottom left reading “scrub” or “shuttle” by hitting the jog and shuttle buttons on the S6, but it doesn’t actually go into or out of those those modes.
I have no idea how it gets into that state in the first place, but it does seem to only happen when there are satellites connected. The systems are a three satellite mix stage.
Old 03-19-2020, 11:57 PM
smurfyou smurfyou is offline
Could it be some sort of Eucon conflict? If it only happens with satellites...
~Will
Old 03-20-2020, 06:08 AM
I have had it happen with eucon turned off, but using icon surfaces (d-control) with satellites also.
Old 12-01-2020, 05:33 PM
JNJ JNJ is offline
+1
This issue has been persistent for a few years now across multiple versions. Happens with Eucon and Icon surfaces. Surface transport button stops working. Only have seen it on rigs connected via Satellite. Seems to happen on the rig not transmitting play selection oddly enough.
Only fix I found is a Pro Tools restart. Anybody with another fix??? Avid??
Scrub/shuttle error Joseph Elliot Pro Tools 11 1 05-15-2016 11:36 AM
8.0.5 shuttle and scrub Random Dude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-07-2011 11:16 PM
Record the scrub / shuttle TheHost ICON & C|24 2 05-26-2004 05:33 PM
trim scrub - shuttle? simonchase Pro Tools TDM Systems (Mac) 0 01-02-2004 10:07 AM
Scrub/shuttle BUG in Ptle ? Paul Curtiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-06-2000 05:37 PM
