Old 07-14-2016, 08:23 AM
innenhofstudios innenhofstudios is offline
Default PT 12.5.2 Offline Bounce - Different Levels after Bounce ??
Hi Guys,
I just made an offline bounce with wav and mp3 at the same time.
mp3 is about 3 dB lower than the wav ???
Then i first did the WAV Bounce and then once more the MP3 Bounce.
Always offline. Also a difference in Level.
Anyone else too? Any Ideas ?
Best René
PT HD 12.5.2, OS 10.9.5, 16Gb 2,4DDR3, 4Ghz ICore i7
Old 07-14-2016, 09:33 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: PT 12.5.2 Offline Bounce - Different Levels after Bounce ??
No I never noticed, but then I only bounce Wav's.
Daniel
Old 01-29-2018, 08:46 AM
kava kava is offline
wow, thats tough.
I experience the same difference, just tried different mp3 encoder settings, makes no difference.
interesting point: theres no difference when I bounce straight waveforms like sinewaves. but I get 3db difference when I bounce pink noise for example. this 3dB peak difference make 0.2dB RMS difference and 0.2LUfs.
so here mp3s are actually louder than the wavs. the sine wave didn't distort, but full range pink noise clips after the reimport of the .mp3.
also checked levels with other software, the PT import is not the problem...
strange and dangerous,
btw. greets from cosmix :)
tom
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15
ProTools Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
Old 01-29-2018, 09:56 AM
Originally Posted by innenhofstudios View Post
mp3 is about 3 dB lower than the wav ???...
How are you measuring these differences? Peak meters? LUFS Momentary? LUFS Long Term? Do they *sound* like roughly the same level? If they don't then there may be something wrong with your encode workflow, but an mp3 will not *measure* the same as a WAV file (in particular peak/short term measurements will be wildly different in unpredictable ways) - you are after all throwing out considerable amounts of data.
Originally Posted by kava View Post
...full range pink noise clips after the reimport of the .mp3...
This is to be expected - one of the many reasons to leave headroom for an encode or decode pass. Lossy codecs (like mp3 / AAC) do not do well with full-level or heavily limited program.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24, 3xS1/Dock.
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 04:55 PM
11.2 Offline Bounce Peter Baird Pro Tools 11 0 08-10-2014 12:23 PM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 06:58 PM
Offline Bounce with New Mac Pro mrtechy007 Pro Tools 11 0 04-28-2014 11:12 AM
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 10:29 PM
