Old 03-22-2015, 01:39 AM
Skwaidu Skwaidu is offline
Default Offline bounce crash, probably Waves-related, and offline bounce not 100% correct
So as per title, anyone else have this? Offline bounce seems to work ok until I insert *one* Waves plugin in to the session, then PT crashes. Even with only 1 stereo audio track. I have the newest Waves versions, Platinum and SSL Soundgrid license (but using just the Native versions).
And on that note, even when offline bounce works it does *not* always work 100%. I have a quite complex master setup on some of my mixes including a processing 2buss with McDSP, Slate, Massey etc and a parallel chain of DUY's DaD Tape (one aux with plugin, one without) after that, if I try offline bouncing that (without any Waves) I get a level difference in the result. I'm thinking it could be the DUY chain as that's the most "esoteric" in my setup, but the fact is that Avid doesn't have it 100% right (unless it's DUY, Slate, McDSP, Massey or someone else bugging out in offline).
Anyone else have these problems with Waves (or anything) crashing offline bounce or offline bounce not being 100% faithful to the mixer?
Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, OSX Mojave, PT Ultimate 2020.5, HDX2, HD I/O 16x16 and ICON D-Command ES.
Old 03-22-2015, 01:59 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Offline bounce crash, probably Waves-related, and offline bounce not 100% correct
Disable the plugins as mentioned above on the mix busses and test to see if it's working ok, it should be. Re-enable plugins one at a time and see if/when problem returns.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-22-2015, 02:01 AM
JFreak's Avatar
JFreak JFreak is offline
I have found sessions without Waves run much smoother than the ones with Waves so it might be related.
But with that said, I normally don't do offline bounce because I want to listen to the bounce while it's being done (quality control) and it's actually faster because if I find something disturbing along the way I can just stop it and fix it. I need to listen to it some time anyway, so the offline bounce is just extra step that takes extra time. Just my thoughts, anyway.
There are also some other 3rd party plugs that make the system unstable, so I only move those to the plugin folder when I really need them.
AAX is still very new format so it'll take some time for plugin vendors to really debug them properly.
Janne
Old 03-23-2015, 04:55 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
If you send me a session in question I can check it out for you - using nearly exclusively Waves plugins here without any issues.
I'm thinking something else is amiss... perhaps version #'s, etc...
For good measure, you could trash Waves prefs/cache and see if that helps.
Again, no issues with Waves here, and our sessions are loaded with them
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Protools 11 with Waves crashing on offline bounce StefB Pro Tools 11 5 02-16-2015 09:35 AM
Offline Bounce Spyderrp7 Pro Tools 11 1 12-18-2014 07:39 AM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 06:58 PM
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 10:29 PM
offline bounce? danielfre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-28-2006 03:04 PM
