Old 01-19-2021, 11:50 PM
Bfearr Bfearr is offline
Default A Setting? Ram?
I've released music in the last 18 months. Some of the track counts went as high as 80 with compression and eq on every track and more on others. Here lately, without having made any changes in ny system, and using as little as 12 tracks, I'm getting that error message that tells you that you can get started again if you get rid of some plug-ins. Granted, it's only 8 gb of Ram and a Pentium i-5, it did the job with my record and its high track counts with lots of plug-ins. Is there a setting I could have touched that would cause the issue? Any ideas?
Old 01-20-2021, 12:18 AM
Default Re: A Setting? Ram?
Take a look at the Help Us Help You document linked to the forum header, please.
Old 01-20-2021, 03:13 AM
Ben Jenssen's Avatar
Yes, you need to provide system details.
But I have some thoughts; I've seen some errors in very light sessions, while being able to run much heavier sessions fine. I got -9173 errors. I suspect Waves LinMB was what caused it in my case.
I think some plugins can cause these things.
Can you see any plugins exclusive to the problem session, and maybe test if the problem goes away if you remove them?
Maximize the HW buffer size, and turn off "Optimize performance at low buffer sizes."
Life-long audio enthusiast and small studio owner. Retired.
Mac mini, quad core i3, 3.6 GHz (Late 2018), 16 GB RAM
Focusrite Scarlett 2i2 3rd gen, Dynaudio BM6's, Command 8 and iPad w/Avid Control.
Pro Tools 2020.11, Mac OS 10.15.7.
Old 01-21-2021, 08:23 AM
Southsidemusic's Avatar
i5 with 8GB ram ...
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-21-2021, 08:52 AM
Originally Posted by Southsidemusic View Post
i5 with 8GB ram ...
Grow up, Christopher!
People have different needs, and PT can run on small processors and little ram if you treat it well.
Old 01-21-2021, 09:10 AM
crizdee's Avatar
crizdee crizdee is offline
Have you added any new plugins into your arsenal? some of the newer plugs can be very heavy on CPU
Are you mixing heavy cpu plugins on the same track? this can cause CPU overloads and error messages!
Do your previous 80 track mix sessions still open and run ok? and are you using the same playback settings?
Have you changed anything else since running bigger sessions?
Chris
Producer, Engineer,
www.ukmastering.com
What do you mean ”Grow Up” ?? i didn’t make the minimum requirements page so dont call people crap for no reason Thank You very Much
And the comment PT can run on small CPU and RAM ... well obviously it can’t since there are hundreds of posts stating the contrary!
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-22-2021, 01:07 PM
arche3's Avatar
arche3 arche3 is online now
Need new computers. You are lucky it runs at all. Protools is a bloated mess of software imo. Only solution is more power and ram.
Other option is use logic pro on an apple m1 laptop. 1100 bucks and it will be stable and fast.
Sent from my SM-G986U using Tapatalk
Old 01-22-2021, 01:48 PM
PT runs just fine on my ancient 2013 trashcan, but maybe it is because my interface is Apogee
Need help setting up my Mic. YungStew Getting Started 4 10-06-2014 01:27 AM
Setting up the I/O - best way DonaldM Pro Tools 11 3 08-14-2014 03:23 PM
Setting up two 192 I/o's richiezo Tips & Tricks 1 07-08-2012 07:39 PM
How do i tell if i which USB setting i have? Dezmond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-15-2004 04:42 AM
What is MP3 setting for MP3.com? novstar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-11-2001 11:59 PM
