Can you use Kontakt standalone without an issue? That would help to know if it's just within Pro Tools, or if it's something with Kontakt and/or your system.
I am using PT 2019.12 HD and I don't have this issue, and nor have I ever had this issue with PT versions that I've been using since v8. I am using the NI S88 keyboard via USB right into my Mac Pro trash can. I also have a USB MIDI interface MOTU MIDI Express XT that works with other MIDI keyboards and my Roland V-Drums last time I checked(about a month ago). What is your MIDI interface? Do you have a USB MIDI keyboard? Do you have another MIDI keyboard you can try? Somehow your computer seems to not be getting the MIDI off note transmission from your keyboard. Can you use the Kontakt built in keyboard in the plug-in with your mouse without issue? In Pro Tools? In standalone? Other VI's work fine? I'm just throwing out ideas for you to try that I would try before saying it's a Kontakt issue.
PT 2020.12 Ultimate HDX, Dual Slate Raven MTi2, HD IO 16x16, Mac Pro 6.1 2013, 12 core CPU, 64GB RAM, Slate VSX, Focal Solo Be6, Roland V-Drums, DW drums, too many VI’s and plug ins to mention |
![]() Quote:
Your right. Its actually still sticking but muting only mutes the sound. My other way is to deactivate kontakt but then it has to load everything again.
10.15.7 (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2020.11 Macbook Pro, 2019 (15,1) 32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2020.5, Apollo 8 Silver,TwinX. |
Same stuck notes here. Sonuscore plug ins. I wish Kontakt 6 could have a midi assignable "!" button because that is my only solution.
1. Find the offending track (out of 100 channels sometimes!) 2. Open the plugin 3. Move to "!" and click... Very time consuming. Even some sort of CC control for the Kontakt Panic Button. Then I could write a bar 1 of my composition with this CC and quickly play it to shut it up! |
Stuck midi notes in Kontakt in PT 12.4 stops workflow | jazubon | Pro Tools 12 | 4 | 03-23-2016 05:54 AM |
Moving MIDI notes and control data (sustain) simultaneously? | tobbenos | Tips & Tricks | 14 | 09-24-2014 12:29 PM |
More effective editing of Notes and Sustain on a Piano (MIDI) track | Stig Eliassen | Tips & Tricks | 4 | 08-05-2013 08:35 AM |
Pro tools 9 and Kontakt 4 - waaaaayyy too many stuck notes | John_Toolbox | macOS | 4 | 05-05-2012 09:02 PM |
MIDI notes don't sustain after being pasted | jimthepisces | MIDI | 1 | 01-08-2008 07:28 PM |
