Old 10-14-2019, 01:20 PM
paul_g's Avatar
paul_g paul_g is offline
Default PT 12 availability
I upgraded my mid-2007 iMac from Lion (10.7.5) to El Capitan (10.11.6) last night. (of course I took a backup first).
After upgrading, PT 10.3 works, barely... It has issues communicating with the Factory 003. I've updated the drivers, etc... no luck.
The uninstaller didn't work, so I had to manually remove pro-tools 10.x
According to the compatibility matrix, PT 12.x is the only compatible version with 10.11.6, however, Avid no longer has it for sale, at least I can find.
It's replacement PT 2018 is not compatible with 10.11.6, so I'm stuck. I think my only option is to restore back to 10.7.5 unless anyone else has ideas...
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 10-14-2019, 01:28 PM
Default Re: PT 12 availability
What exact iMac is this EMC or model number please...
El Crapirain is a bit very unliked release by many of us.
Why did you upgrade/what problem are you trying to solve?
A core 2 Duo may be underpowered for your needs... it’s certainly under-minimum spec for any modern version of Pro Tools.
4GB really is not enough to run Pro Tools 111/12 or later.
What Exact Pro Tools license do you have. You can purchase perpetual upgrades that get you 10/11/current releases tgat will also run 12, and if you have a license for 12 and ask nicely Avid will deposit 12 downloads in your aaccount if they are not out there automatically.
Rolling back to a backup may be the best option.
Old 10-14-2019, 03:57 PM
paul_g's Avatar
>>> Model Identifier: iMac7,1
>>> I can see why, PT 10 / 11 isn't compatible, and one has to upgrade to PT 2018.
>>> None, other than the fact my system is old, browsers aren't supported, I can't run any of the Line6 Helix software, etc...
>>> Perhaps you are correct. Seems to work fine at Lion and PT10, no issues through the years.
>>> I agree 100%. Other World Computing states an old mid-2007 iMac can be upgraded from 4GiB to 6GiB of RAM with a (4+2) pack. I had intended on upgrading the RAM if all played nicely. Few years back I put in a 480GiB SSD drive and that works very well.
>>> I started on PT 7, and did upgrades from there. I purchased an upgrade for PT 9, which then got me to PT 10. That's it, I have no more licenses.
>>>> I did, thank goodness for Time Machine and my WD MyCloud! :) Everything is back working again on Lion & PT 10.
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Availability of 7.3????? MiamiMusicMan Pro Tools TDM Systems (Mac) 1 10-23-2006 02:21 PM
PT 6.2 availability with G4/OS 10.2.x Ricky Cobble Pro Tools TDM Systems (Mac) 1 11-15-2003 10:38 AM
PT/NT 5.1 availability Echo studios Pro Tools TDM Systems (Win) 8 02-23-2001 10:23 AM
OS 8.6 availability? Craig Woolard Pro Tools TDM Systems (Mac) 9 01-12-2001 06:12 AM
Os 8.6 availability roderickelms Pro Tools TDM Systems (Mac) 5 09-08-2000 02:40 PM
