Playing back midi track with Reason
HD 3 6.1 How do I quickly play back a midi track recorded in protools through a Reason sampler or synth? Thanks
bookerv12 |
Re: Playing back midi track with Reason
Hey;
Create a stereo audiochannel in protools. Insert the reasonplug (rtas) in protools and set it to receive mix L-R In reason, the easiest for me is to put the synt via the internat mixer and then set the mixer out put to channel 1-2 on the reason "virtual" audiointerface. set reason to rewire slavemode. then you should be able to see all the reason instruments when you select your midi outputs in protools edit window Works well for me!
Tremolo |
instrument track not playing back MIDI | apartmentstudios | Windows | 1 | 01-11-2013 07:08 AM |
Click track playing back when muted. | ericsvizeny | Pro Tools TDM Systems (Mac) | 2 | 05-31-2011 09:10 AM |
protools not playing back without reason | insomniac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-23-2010 01:40 PM |
Track volume goes down when playing back! | tunecrab | Pro Tools M-Powered (Win) | 1 | 05-23-2007 02:00 AM |
Click track(s) not playing back properly | Blueswah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-08-2007 06:06 AM |
