Old 11-23-2010, 08:20 PM
StudioAlethea StudioAlethea is offline
Default Pops and Clicks during tempo changes in PT8 with Xpand2!
I am having issues with clicks and pops in the playback/ recording of Xpand2! whenever there is a tempo change.
I have tried all buffer and CPU settings to try to rectify the situation-- no help.
I have tried trashing databases and preferences-- no help.
I have tried uninstalling PT entirely and reinstalling-- no help.
I have actually done this many times.
It is not session specific, because I have opened up a blank session, added a virtual instrument track with just one instance of Xpand2! on it, added a bunch of tempo changes, and the pops and clicks come up.
I don't have any other MIDI clocks or any slave/ master relationships.
I have isolated this to Xpand2! and no other plug-in instrument so far.
I have also gone back and tried every version from Pro Tools 8.0 vanilla up through 8.0.4cs3 (i think is the last one).
Please, help if you can!
Old 11-23-2010, 10:01 PM
Default Re: Pops and Clicks during tempo changes in PT8 with Xpand2!
There is no solution, currently.
Aaron Mulqueen - 001 HD Native
Old 11-24-2010, 11:22 AM
Is this a known issue for Xpand2? I've seen lots of posts about similar problems, but not this one specifically.
Old 11-24-2010, 07:50 PM
I believe so.
Old 04-03-2018, 09:14 AM
Spoil the Child Spoil the Child is offline
Hello! I know this is a super old thread. But just in case it might help someone who's still using Xpand2 (like me! ), I found that turning off certain effects in the FX 1 AND/OR FX 2 sections in the Xpand2 GUI instantly gets rid of the problem.
Once, I had a vocal pad patch in Xpand2 that I believe had the FX 1 "on" by default upon choosing the said patch. The effect in FX 1 for this vocal pad patch was "Chorus" (which was also what I had wanted to use as well). But, as has been said, there'd be pops and clicks. Once I had turned FX 1 "off", though, the clicks and pops were completely gone!
What I did after was that I bussed the track in question to an aux track, added the effect there instead, then rendered the audio. It's not a perfect workaround, but it worked for me.
Hope this helps.
Xpand2 Loops not matching tempo bryced87 Virtual Instruments 0 10-08-2011 07:48 AM
Xpand2 adjust vibrato rate to match tempo skronger Virtual Instruments 10 09-26-2011 07:13 AM
Clicks and Pops in Xpand2 Nano Virtual Instruments 6 01-29-2011 11:40 AM
Pops and Clicks -- 7.4 and 7.4.2 mac pro mikevarela Post - Surround - Video 14 08-22-2008 09:52 AM
Pops & Clicks in PT 6.41 TuT Pro Tools TDM Systems (Mac) 4 11-02-2004 07:57 PM
