Old 01-21-2020, 02:50 AM
AudioUproarBen AudioUproarBen is offline
Default 2019 Video Engine Bug
Hi, I've recently updated from PT11 to PTU 2019.10 but I'm struggling with getting video to be displayed via a Blackmagic decklink mini monitors HDMI output. Along with the update the OS went from Mavericks to Mojave, update not fresh install.
I've found a video it likes (h264 .mp4), I can import this and it will play fine. Any video I import after this will play fine. If I import any other video first, I get no output on the TV but I can see it in the PT Video window. It seems it breaks the output, I can work around it by deleting all the videos from the clip list and removing all the video tracks, importing the known good video and then the video I want.
I've tried using a AJA Kona LHi video card but its no better.
I've tried 2019.12
I'll try 2019.6....
iMac with Decklink mini monitor in a magma chassis
Many Thanks
Old 02-01-2020, 10:08 PM
danielsun_ danielsun_ is offline
Default Re: 2019 Video Engine Bug
Hi Ben,
I would convert all your videos to the DNxHD codec and only use that codec for all video playback.
remove any other videos that have a different codec from your PT session.
Then import the DNxHD ones.
Good luck
HTML code is On
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
Problem enabling video engine 2019.6 Lydbildet Windows 12 04-02-2020 10:24 AM
Bug in new video engine 2019.10 Meads Post - Surround - Video 40 03-23-2020 08:36 AM
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 01:22 AM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
