Old 01-20-2020, 05:51 PM
jbreher jbreher is offline
Default 2019.12 HD Driver install bricked my MBP
Like the title says.
PT 2019.12 Ultimate had been working on this machine (late 2019 16" MBP - see sig) with generic USB interfaces (e.g., Aphex 500 Rack).
Today was the day I was to move my HD Native system from my 2009 Mac Pro (see sig) to the new MacBook Pro, using a Sonnet Echo Express III TB-PCIe Expansion chassis.
No problem with the HW install. Mac System Information indicated all as expected.
Hooked up my Mini DigiLink cables - no detection of HD I/Os nor OMNI.
Internet sleuthing indicated drivers need be installed after PT. OK, I'll install the drivers.
Driver install process reaches a dialog that indicates system will reboot. System goes down...
Apple logo...
Progress bar...
About 95%...
About 95%...
About 95%...
After about a half hour, I powered off and back on
Apple logo...
Progress bar...
About 95%...
About 95%...
About 95%...
After another 20 minutes or so, I powered off and powered back up into safe mode (hold Shift key).
Apple logo...
Progress bar...
About 95%...
About 95%...
About 95%...
It's been over an hour now. The PT HD Driver install process has evidently bricked my computer to the point that safe mode does not even work. Any ideas how to get past this?
PT on the MBP is 2019.12 Ultimate - matching driver release.
MacPro Early 2009 - 2.66 GHz Quad Xeon, 20GB 1066 MHz DDR3, AMD Radeon R9 280X 3072 MB, OSX 10.8.5
PT 10.3.8.378, HD Native PCIe, HD I/O 16A, HD I/O 8x8x8, OMNI
MacBook Pro 2019 16" - 2.4 GHz 8-Core i9, 64 GB 2667 MHz DDR4, AMD Radeon Pro 5500M 8 GB, macOS 10.15.2
Old 01-20-2020, 09:07 PM
LukeHoward LukeHoward is offline
Default Re: 2019.12 HD Driver install bricked my MBP
NB: PT might not work with Thunderbolt 3 chassis.
I would start your laptop in target disk mode and trash /Library/Extensions/DigiDal.kext. See if that helps... (obviously you'll need another Mac to do this)
https://lukehoward.com/
Old 01-20-2020, 10:10 PM
Intriguing.
MBP 16" Has only TB ports - which I guess operate as USB also.
My Mac Pro 2009 of course has no TB. But it has USB. But that would require an A-A cable. Not sure I have such.
I think I have an old 17" MBP - which likely has FW. But how to bridge that to TB?
Can anyone point me at a reference? Don't know if I've used target mode in the last decade. Fumbling.
Old 01-20-2020, 10:25 PM
Hmmm. Connecting it up to an OWC TB2 dock, connected to ethernet.
I can ping it.
ssh gets connection refused. Not sure if I've ever tried to ssh into it before.
Old 01-20-2020, 11:21 PM
Southsidemusic's Avatar
Have you done the security settings so the new Macbook is allowed to see the interface as apple changed that with Mojave and upwards so you might need to set the security settings manually.
And also do you have the digilink license on your ilok key as thats needed after PT12.6 HD which might be included in Ultimate and if it is then it will be inside your ultimate bundle on the iLok. Otherwise you have a $299 purchase to take care of before you can use the card and interface. What PT version was the last you used with You card and digilink interface before going to Ultimate and had it working? If it was PT10HD (On the old mac pro) then you NEED the Digilink license..
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-21-2020, 12:31 AM
LDS LDS is offline
My 2018 MBP had similar hanging when an eGPU was attached. Unplugging it while OSX loads, then plugging it in after the desktop appeared seemed to work fine in sorting it out. It randomly stopped happening one day, I think after an OSX update. Have you tried doing something similar?
TB3 isn't technically supported with HDX and Pro Tools yet. There are details about it on the Sonnet website. Their solution is to downgrade the Echo Express III to TB2... it costs $150 though. With that being said, Avid have announced TB3 versions of HDX using custom sonnet enclosures so TB3 support might be appearing in the next Pro Tools release.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 01-21-2020, 09:21 AM
I really don't know. And seeing as my machine won't boot, I have no way to check. I would have thought the PT install process would have taken care of this, would it be necessary. Then again, I would have thought the PT installation process would have installed all necessary drivers to begin with. You know what they say about assumptions.
FWIW, PT 2019.12 Ultimate worked on the new MBP with USB interfaces before trying to move the HD Native system over to that new machine. DOes this answer the security settings question?
Yes, the iLok does contain the DigiLink license. It came with my OMNI. The previous version used (2009 on the Mac Pro) was indeed PT10HD (specific release in sig). But I was already aware upgrading would require the DigiLink license, so I activated it on my iLok.
Old 01-21-2020, 09:26 AM
Well, I have tried booting it in safe mode without the TB-PCIe chassis attached. Indeed, before bed last night I tried booting in safe mode with nothing atttached but the power supply. This morning, it is still hung at the apple loga and near-complete boot progress bar.
Yeah, I was aware of that. My sales rep suggested it was probably just a matter of not having been formally tested yet. And that it would 'probably' work. Promised to make it right if it did not. But I don't think 'make it right' would include restoring a bricked laptop to functionality.
Old 01-21-2020, 09:28 AM
Have you done this:
http://avid.force.com/pkb/articles/e...nput-on-Mojave
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-21-2020, 09:54 AM
I think so. I would not have been able to record and play back using my Aphex interface if I had not, correct? I’m not positive, as the machine won’t boot, so I cannot check.
HD Native Core Audio Driver 2019.12 Justin1524 Pro Tools 2019 6 01-29-2020 09:29 PM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
Avid 2019.6 HD Driver & OSX 10.15 LDS Pro Tools HDX & HD Native Systems (Mac) 1 10-17-2019 07:34 PM
HD Driver 2019.5 issues with third party interfaces PT user Pro Tools HDX & HD Native Systems (Mac) 0 06-04-2019 11:56 PM
PT 2019 Core Audio Driver? gearhead2010 Pro Tools 2019 0 05-09-2019 12:44 PM
