Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 08-12-2018, 04:15 PM
QuikDraw's Avatar
QuikDraw QuikDraw is offline
Default Presonus Studio One For Performance
I never thought I'd say it, but I'm actually considering switching to another DAW. Been using PT since 2000 with PTLE 5.1 on PC. Now running PT 2018.7 on both Mac and PC.
Performance has always been a challenge in PT vanilla. I've always been able to get by with high buffers, and monitoring through an external mixer for zero latency, and I always just assumed that this was normal.
I recently purchased a Presonus Quantum 2, which they claim is the world's fastest interface. At first I was impressed. I was able to get it down to 64 samples in Windows, but I eventually found out that random CPU spikes actually made that setting unusable. So I have to run at 128 samples. Too much latency for tracking through plugins. Somehow PT has managed to take the fastet interface in the world, and make it run like any run of the mill USB interface!
On Mac I can reliably run it at 32 samples, but I'm just not comfortable in Mac OS.
Then I tried Studio One 3.5 Artist that came with the Quantum 2. Wow!
I can run reliably at 16 samples, and the CPU never breaks a sweat! Never over 10% ever! PT doesn't even see 16 samples as an option. At 16 samples, latency is a thing of the past.
I'm still pretty uncomfortable with S1, but I'm quickly getting used to it. Unfortunately the Artist version does not allow 3rd party plugins, so I'll have to pony up $300 for the pro version before I can try tracking through Amplitube 4, but I think I might just give it a try.
I'm sure I'll keep using PT if only for mixing. The UI is just so easy to figure out. I mean, if you've ever used a mixer and a tape recorder, you can use PT. No manual needed.
-- Mike
- HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics
- Windows 11 - PT 2021.12
- PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i
- Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs
Old 08-12-2018, 05:54 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Presonus Studio One For Performance
I'm getting ready to jump off the Avid train at the next stop.
Like you, I've been using PT for a long long time and it feels like the railway lines are getting too rough. Maybe because I'm getting older....I'm feeling all the bumps.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 08-12-2018, 10:01 PM
Top Jimmy's Avatar
Don't you get $100 off of Pro if you have Artist registered?
James Cadwallader
Old 08-13-2018, 09:08 AM
QuikDraw's Avatar
Yes. The full price it $400. I also looked at crossgrade. It's 25% off. $400 - ($400 X .25) = $300.
I also looked at upgrading to S1 4 Artist upgrade then Pro upgrade. $50 + $250 = $300.
-- Mike
Old 09-14-2018, 12:11 AM
xrekcor's Avatar
xrekcor xrekcor is offline
so did you upgrade Studio One? how you travelling with it?
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 09-14-2018, 07:54 AM
QuikDraw's Avatar
I haven't upgraded to Pro yet. Still using 3.5 Artist. So no VST plugins yet.
I still like PT better except for the performance, but I've gotten to the point where I can work in S1 most of the time without getting frustrated.
The stability and performance is incredible. PT can't touch that.
-- Mike
Old 09-14-2018, 02:58 PM
xrekcor's Avatar
ok thanks, I'm looking at possibly getting a PreSonus series 3 SL32... and it looks like I will be pretty much stuck with SO while they work on the hui protocol so's other DAWs can access their DAW control. can you open your SO projects in PT? or export them across some how?
also can PT see your Presonus Quantum 2 ok?
Rob
Old 09-15-2018, 02:15 PM
QuikDraw's Avatar
I don't know about opening a SO project in PT. I haven't tried that. I'm running SO 3.5 Artist. Looks like they didn't include OMF or AAF export until version 4. So if you get version 4 you might have limited success in exporting something PT can understand.
Yes, PT sees the Quantum 2 interface, and I use it all the time. But in PT the Quantum 2 doesn't perform any better than any run of the mill USB interface. In SO the Quantum 2 really shines!
-- Mike
Old 10-14-2018, 05:42 PM
QuikDraw's Avatar
I finally upgraded to Studio One 4 Pro. As I suspected, I am able to reliably track with a 16 sample buffer with Amplitube 4 active on the record enabled track. It's completely stable. I Pro Tools I have to run 128 sample buffer to get a mostly stable system, and that's too much latency to track through Amplitube.
It's too bad Avid can't seem to figure out how to run a stable system at low sample buffers. I'm way more at home in Pro Tools. There are still some very basic audio editing tasks that I have yet to figure out in S1 that are no brainers in PT.
Oh well. I have both, so I'll use whichever is best for the task at hand. Probably S1 for Tracking, and maybe PT for editing and mixing. But I am getting more comfortable in S1. I might eventually stop paying for an Avid subscription.
And I love Melodyne! Too bad it's the Essentials version. There's just enough there to make me want the full version!
-- Mike
Old 10-14-2018, 06:18 PM
Your best bet for moving a project from any DAW to another is to consolidate all audio back to time zero and export wave files. OMF often disappoints
FS: Presonus Studio One 3 Professional JoshuaTheKvlt Buy & Sell 19 03-24-2017 02:19 PM
Presonus Studio One is Looking Better Every Day... Justin1524 General Discussion 42 03-10-2016 03:13 PM
FS: Presonus Studio One 3 Pro pmcaster Buy & Sell 0 11-07-2015 02:09 PM
Using PT 9 and Presonus Studio Live 16.0.2. Rescued Pro Tools 9 1 10-31-2012 10:32 AM
Presonus Studio Live and PT9 pappatoad macOS 1 01-29-2011 12:22 AM
