Old 01-13-2013, 02:20 PM
vw45 vw45 is offline
Default Pro Tools 10 with Behringer Xenyx Mixer
Hi all,
I'm having trouble getting my Behringer Xenyx 1204 mixer to record into Pro Tools 10. I'm using the mixer as an A-D converter so I'm plugging it into my laptop (mac) with a usb cable. I'm able to monitor off the mixer from pro tools but I can't get a signal path input. It even disables my laptop built-in microphone (not that I'm going to use it anyways). Just wondering if anyone knows if this hardware is Pro Tools compatible and how I can record into my laptop through USB?
Thanks!
Old 01-13-2013, 02:43 PM
zolko zolko is offline
Default Re: Pro Tools 10 with Behringer Xenyx Mixer
Is Xenyx seen in Setup/Hardware window? Are you able to set Default paths in Setup/I/O window?
Old 01-13-2013, 10:00 PM
It comes up as USB Audio Codec in the Hardware Setup.
Nothing shows up in the I/O input anymore. Not even my built in mic, I feel like I've messed something up when testing out different things in the Hardware Setup.
Old 01-15-2013, 01:17 PM
sixteensquares sixteensquares is offline
I'm interested to see what the possible solutions are - I'm having the exact same issue with my setup and integrating a Xenyx X1204 into PT 10. The only work around that I can think of is running the main L/R outs into the TRS inputs on the MBox 2, but I've not had any luck recording into PT directly through the USB connection on the X1204.
Old 01-15-2013, 04:00 PM
Yeah, im hoping to bypass the audio interface and go direct into the laptop. I don't have an audio interface anymore.
Old 09-28-2016, 11:39 AM
turfgurutigers69 turfgurutigers69 is offline
Recently just got the behringer x1204 mixer and was told at guitar center by the audio pro I can use it in pro tools 11. However, when I try to open pro tools it blocks me out and says to plug the inter face in.. so i cant even get to teh setup screen to change anything in order to use teh mixer.
Old 09-28-2016, 11:52 AM
Uh oh "Audio Pro" and "Guitar Center" in the same sentence. Oh and any lack of even a hint about what computer you are using. I'm predicting this is not going to go well for you.
Your mixer is stereo USB Out only, it has very limited use with a DAW, basically just recording the analog mixer mix-down. Is that what you want to do?
I can't guess what platform you are on, this is class compliant on OS X and needs ASIO4ALL on Windows. If on Windows did you install ASIO4ALL? If so start up Pro Tools and hold down the N key and keep it held down until he playback engine dialog panel appears then select the mixer as the playback engine, it may be called ASIO4ALL.
Overall if you are after an audio interface for recording multiple inputs with Pro Tools this ain't it. Hopefully you actually wanted an analog mixer for live use.
Will Pro Tools work with my Xenyx Mixer? tunaman14 ProControl, Control|24, Command|8 3 08-14-2012 06:20 AM
Pro Tools 9 and Behringer Mixer Bos Def Pro Tools 9 8 12-24-2010 10:29 PM
behringer xenyx usb mixers robertcici ProControl, Control|24, Command|8 2 11-11-2010 06:55 PM
mbox 2 and Behringer XENYX 2442FX mixer ultimateguitarfish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-17-2010 09:21 AM
Help setting up Behringer Xenyx 802 mixer with Audiophil2496 bunderson Pro Tools M-Powered (Win) 1 04-26-2008 09:00 PM
