Old 07-23-2015, 03:53 PM
tronic21's Avatar
tronic21 tronic21 is offline
Default Pro Tools 11 doesn't work,Sesions open then pro tools stop responding
I have a macbook pro 2.6 ghz i5 8 gigs of ram
running Pro Tools 11.3.1
I try opening my existing sessions and pro tools stops responding
I try a new session and it stops responding
I have tried taking all plugins off my older sessions doesn't help
I have absolutely no clue what to do, maybe there is a preference that can be deleted or maybe a folder that needs deleting
I have also repaired my disk as well as the permissions
I'm stuck, if you can help me out that would be great
thank you
Old 07-23-2015, 06:31 PM
Chief Technician Chief Technician is offline
Question Re: Pro Tools 11 doesn't work,Sesions open then pro tools stop responding
Which version of Mac OS X are you using? Have you moved all third party plug-ins from /Library/Application Support/Avid/Audio/Plug-Ins to /Library/Application Support/Avid/Audio/Plug-Ins (Unused)? Have you tried another OS X user account?
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 07-23-2015, 07:18 PM
tronic21's Avatar
Default Re: Pro Tools 11 doesn't work,Sesions open then pro tools stop responding
I am running OS X 10.10.4 Yosemite
It does give me an option to be put in unused but I thought that then the plugin would not work
Old 07-24-2015, 06:58 AM
Lightbulb Re: Pro Tools 11 doesn't work,Sesions open then pro tools stop responding
This is true. If a plug-in is in the unused folder, it is not available for use. Given that you are having problems doing the basics, it might be worth moving all non-Avid plug-ins into the unused folder and seeing if you are then able to create a new session without Pro Tools going into a non-responsive state.
Old 07-24-2015, 11:27 AM
It may also be worth trying this trick; hold the SHIFT key while you open a session. That command makes all plugins inactive. USUALLY, if a plugin is the issue, this will allow the session to open, and then you know its plugin-related(helps a bit with troubleshooting)
Old 07-27-2015, 01:14 AM
tronic21's Avatar
Unfortunately I am still having problems its like pro tools picks and chooses, i'll open the session and most of the time it opens and right away stops responding, sometimes I can get maybe 5 minutes before it stops responding 1 time yesterday I got about 30-45 minutes to use it before it stopped responding, I did disable the plugins and it made no difference it just doesn't seem to have a rhyme or reason I can't pick up a pattern like if I hit record, or use the faders or open other windows, it doesn't seem to matter
Old 07-31-2015, 02:27 AM
tronic21's Avatar
Someone had mentioned trying a new account on the mac and I did an still the exact same problem of the session not responding either immediately or 5-10 seconds in
Alt Tab doesn't work when Pro Tools is open weezerboy Windows 26 09-30-2022 12:09 PM
Bought Pro Tools 11(academic), given pro tools 12 licence, doesn't work! TimCollins1311 Pro Tools 11 2 03-17-2015 09:52 PM
Mackie MCU + XT midi drop out in Pro Tools HUI errors controller stop responding Tony_Nailz MIDI 5 02-23-2015 07:58 PM
Spacebar doesn't work as start/stop with plugin open Downtown_BE macOS 6 11-05-2014 06:19 PM
Pro tools doesn't know when to stop! svenhardini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-05-2009 11:14 AM
