Unable to write CC automation data in real time
I recorded a midi track and now I want to go back and automate CC1 (Mod wheel)in real time using my midi controller. When the automation tab is in READ mode and I play back the midi track I can hear the mod wheel control the volume in real time. However whenever I play back the track in WRITE mode for recording the automation data I am unable to write anything. It's as if Pro Tools is not recognizing my controller during write, latch or touch mode.
Can't figure out what I'm doing wrong.
- Steve 2013 iMac Late model i7 3.5 Ghz quad-core, 24 gigs ram, OSX 10.12.3 PC slave, i7 6700 4.0 Ghz quad-core, 64 gigs ram, SSD drives running VE Pro 7 Multiple external thunderbolt SSD hard drives UAD Apollo X8, Twin Duo & Quad Satellite Thunderbolt Townsend Sphere L22 w/ Putnam Mic Collection LUNA (I have Pro Tools 2020 as well) |
Re: Unable to write CC automation data in real time
Hi, Mod wheel is written as midi data not automation data. need to arm a new midi track and write it, then you could merge it onto one track if you wanted. Or you draw it in using the midi edit window Chris
Thanks for the reply Chris I will try that.
I also have a CC controller that is configured to control any CC data I want, such as CC1, CC11, etc. Can that kind of midi data be automated using the WRITE function under the original midi track? If not then, then out of curiosity, what kind of midi automation data can you write in real time using a midi controller under the CC lanes of the original track? In other words, what is the WRITE, LATCH, TOUCH used for in midi tracks if something as basic as mod wheel data cannot be used there?
Hi, Yes you can automate midi control information, but its separate from the automation like on audio tracks. if you're on an instrument track then you'll have midi control data and some general track automation control for volume / pan / mute etc. Chris
Indeed^^^ Sometimes its tough to figure out which CC is the one you really want, so try any until you manage to get the correct one. Since(as said already) its midi data, I would enable Midi Merge and put the instrument track in record and try updating the CC info that way(and maybe delete all breakpoints before entering record). Midi is sometimes much less intuitive than audio
Unable to write automation | bikkuri | Getting Started | 2 | 08-03-2017 04:42 PM |
Can I Record Real-Time Expression/Mod Data in MIDI Tracks? | MogDog | Pro Tools 10 | 4 | 10-25-2013 04:46 AM |
real time automation | jahlive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-30-2009 10:56 PM |
Waves real time automation | ToddSmith | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-07-2005 08:59 AM |
Automation Real-Time | Imagine | Pro Tools TDM Systems (Mac) | 0 | 08-06-2004 08:41 PM |
