Old 09-24-2015, 05:35 PM
Bender Bender is offline
Default OSX Version error
Solved
I am trying to install PT10 on my MBP (new drive, used this computer for 3 years) and on install I get an error that my OSX version in not new enough. I am up to date
Anybody see this before
Thanks
MacBook Pro (13-inch, Mid 2012)
2.5 GHz Intel Core i5
8 GB 1333 MHz DDR3
Old 09-24-2015, 09:17 PM
Default Re: OSX Version error
PT10 was only certified to work up to OSX 10.8.x (Mountain Lion). Users here have it working in 10.9.x (Mavericks) but the uninstaller does not work. For OSX 10.10.x (Yosemite), it won't install because the installer sees 10.10 as 10.1 therefore you get the error you are seeing. Additionally, there is a major problem running PT10 in Yosemite in that the pull down menus first appear blank until you mouse over them but they remain blank after you pass through them. The uninstaller still does not work in OSX 10.10.x.
In the future, please check the compatibility chart first before installing Protools with any version of an operating system.
You best option is to either format your drive and install Mountain Lion and then Protools 10, or upgrade to Protools 12 and run that on your Yosemite drive.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 09-25-2015, 07:43 PM
Exclamation Re: OSX Version error
The officially unofficial way to install Pro Tools v10.x on OSX 10.10.x (Yosemite). As Obsidian Dragon said, this combination has issues. Proceed at your own risk.
Old 09-26-2015, 01:08 AM
Thanks
Old 09-26-2015, 12:14 PM
TiPo TiPo is offline
Will Pro-Tools 10.x.x ever be compatible with OS X 10.10.x or is it stuck at a more then 3 years old OS namely OS X 10.8.x thus leaving us stranded?
What is the problem? Is it a coding issue or a marketing strategy?
TiPo
Pro-Tools 10.3.10 HD 2 Accel PCIe
OSX 10.10.3
Old 09-26-2015, 12:52 PM
Southsidemusic's Avatar
PT10 is end of life regarding support as we are as you said 3 years into the future on PT12 so I wouldn't bet the horse anymore updates will come out. Avid have supported PT10 for 3 years now and we have a stable version of 10 and it does work on 10.10 but you need to do some workarounds when installing and unistalling.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-26-2015, 10:35 PM
Thank you Christopher!
TiPo
OSX 10.10.3
Error Installing Trial Version GTBannah Pro Tools 11 11 03-13-2014 04:32 AM
"older version of Pro Tools" error HearInc Pro Tools TDM Systems (Mac) 7 08-18-2008 11:11 AM
Alternate Version of the "unqualified version of 7.4.2 Error" MrVerbz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-03-2008 07:29 PM
Error 9131 On 6.7 version soosul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-21-2008 08:33 PM
