Old 01-21-2008, 08:35 AM
ChrisMurray ChrisMurray is offline
Default importing Audacity tracks into ProTools LE
Can anyone advise me on ways to import a recording done with Audacity 1.2.6 into ProTooks in a way that maintains the individual tracks? Thanks in advance, Chris Murray
Old 01-21-2008, 10:05 AM
jskell jskell is offline
Default Re: importing Audacity tracks into ProTools LE
You would need to export each individual track as a separate wave file.
Highlight the track, click file -> export selection and take it from there.
MacBook Intel Core 2 Duo 2.4GHz, 4GB RAM. Lacie F250 HDD for audio.
M-Powered Setup- M-Audio 1814/M-Audio Transit
LE Setup- MBox2 Mini/MBox1
Old 01-22-2008, 04:13 AM
<- You would need to export each individual track as a separate wave file. Highlight the track, click file export selection and take it from there. ->
If you then import each track as a WAV into a PTLE file, will the tracks remain in sync?
Old 01-22-2008, 05:40 AM
Assuming that each individual track has audio from the beginning onwards, then yes. You're basically aiming to create a series of wave files that are the length of the overall project, then import these into Pro Tools.
Old 01-22-2008, 10:57 AM
The Weed's Avatar
The Weed The Weed is offline
Consolidate every track from 00:00 to just past the end of the project so each track's consolidated region starts and ends at the same time. Import these wave files into Pro Tools each on separate tracks with the start time of each wave file at 00:00 and they should all line up perfectly.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Using Audacity Sonny in London 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-06-2006 07:51 AM
Audacity? RobN General Discussion 1 06-28-2005 08:03 AM
importing garageband tracks into protools? Tex Tiles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-25-2005 06:10 PM
Importing CD tracks Dutty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-21-2003 02:42 PM
importing CD tracks Ricco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-09-2002 06:54 AM
