System memory issue ... OS X
I'm having a problem with a Playback Engine issue in version 6.0.1. In the DAE Playback Buffer when I have the "size" Level on anything greater than Level 0, I get; "REQUIRES xxMB OF SYSTEM MEMORY. YOU HAVE 5MB ALLOCATED. A RESTART IS REQUIRED". The only way I'm able to get past that is setting the DAE Playback Buffer to 0 because it always says YOU HAVE 5MB ALLOCATED no matter what I set the buffer level to. I get "Pro Tools was unable to adjust your system memory settings, you must have a valid admin password to change these settings". How do I get that system memory to increase?
FYI the "Minimize system memory allocation (takes effect at next restart) is always greyed out. How can I fix this problem? Can you tell me what the Mix TDM Settings should be set to: H/W Buffer Size? CPU Usage Limit? Can these setting be a part of solving the problem? Thank you, Shawn Conrad G4 450, 768ram OS X 10.2.6 Pro Tools version 6.0.1 Mix Plus (Core and Farm) seperate Audio and video firewire drives USD 888/24
Thank you, SPC |
Re: System memory issue ... OS X
never done any PT in X, but it sounds like a permissions thing. Are you logged in as a user with Admin priveledges?
'best Tom |
Memory usage in lion issue | crizdee | Pro Tools 10 | 3 | 01-05-2012 09:49 AM |
Presumably a memory issue? | jimdpie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-15-2011 07:29 AM |
PT 8 and 9 Memory leak? and Waves issue | thierryd | Post - Surround - Video | 3 | 11-23-2010 10:16 AM |
Memory Issue | TLarvenz | Pro Tools TDM Systems (Mac) | 22 | 04-27-2009 08:28 AM |
Minimum memory issue | clutch | Pro Tools TDM Systems (Mac) | 1 | 12-04-2002 12:12 AM |
