Protools low on memory?
I recently read a post about protools saying it was low on memory. The user had a new Imac. (I'm assuming it was the mid 2011 model.) Well come to find out while i was mixing a session i encountered the same problem. It happened while i was about 30 to 40 minutes in the session. The user with the prior post didn't mention when it happened to his. Anyway i was using elastic audio to correct timing issues on some drum tracks. What i was doing was manually fixing the hits the computer didn't fix when i quantized. So as i was literally going through and fixing pretty much every bit, it happened. I'm also using a new Imac (the mid 2011). I'm running protools 8.05 with a digidesign 003+. The Imac is a 2.5 ghz with the new i5 quad core processors running 10.6.6. Any help would be appreciated. Thanks
Protools is low on memory... | lukeyy | macOS | 5 | 02-21-2012 05:49 AM |
Protools Le 8.0.1 Draining Memory Win Xp | JamesPondAqu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-17-2009 08:49 AM |
how much memory i need to run protools | streets | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 06-12-2004 11:13 PM |
Allocating Memory to ProTools and DAE | CircleMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-22-2003 07:16 AM |
ProTools CRITICALLY LOW on MEMORY??? | BrandonABrown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-01-2003 11:25 AM |
