Old 07-10-2018, 07:02 PM
mtwhite mtwhite is offline
Default I/O Setup Question
I'm having trouble getting the playback/monitor settings to work for me.
Here is my setup:
Instrument>Behringer 12 Channel USB mixer>iMac>Pro Tools.
I've pulled up an existing project with a drum loop.
I have tried Pro Tools Aggregate I/O and USB Codec and neither will allow me to hear any track. I have tried headphones into the Behringer and into the iMac. I can hear other programs through the iMac (iTunes for example) and I can hear the instrument live through the Behringer. I know that part is working.
With the above configuration, how should my I/O, Hardware and Playback Engine be set?
Thanks for any help.
Old 07-11-2018, 12:27 AM
Stig Eliassen's Avatar
Default Re: I/O Setup Question
https://www.sweetwater.com/sweetcare...the-same-time/
It includes a link on how to create aggregate devices.
Hold down the N key until the Playback engine window opens when launching PT, and make sure the correct device is selected. I've never used aggregate devices, but I assume you can default the I/O just like with other devices. Have you tried that?
Old 07-11-2018, 05:02 PM
Thanks. I have used the PT aggregate which is installed by default on install. It’s just that I’m not hearing anything. I’m at the point where I might just reinstall and see if that resolves it.
Thanks for the reply.
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
Setup question JNS Pro Tools TDM Systems (Mac) 3 03-02-2010 11:19 AM
Setup question Nils Groth Pro Tools TDM Systems (Mac) 2 11-18-2008 07:22 PM
I/O Setup question scottgreiner Pro Tools TDM Systems (Mac) 9 05-19-2007 01:18 AM
Setup question: no 192 w/ DS-M7.1? Tom H Pro Tools TDM Systems (Mac) 2 01-18-2005 03:03 PM
