Old 07-01-2018, 04:09 PM
cstocker77 cstocker77 is offline
Default a session recorded in PT10, opened in PT11. NOISE!!!
I found a trusted friend who has an installer for Mac OS Yosemite. I recently have been experience H/W Buffer errors everytime i mix, using 3rd party plugins, the stock plugins, or no plugins at all.
I recently purchased a used Apollo, 1st ed. from another trusted friend.
I was using PT 10, with Mountain Lion for many many years. Basically, it was a compromise i had to make due to the hardware I owed for the last 10 years.
Now that I have Yosemite, I had to start using my PT 11. Seems fine, I installed it, updated my ilok, etc. (I have not updated my Apollo driver yet, nor have i updated any of my 3rd party plugins).
But today when I opened a session that I previously recorded with PT10, in PT11- I was experiencing lots of background noise during playback. Any of the tracks that had plugins on them I had made inactive. All I was listening to was a stereo track of the entire mix, and the Master channel. neither of which had any plugins assigned. I was opening PT 11 with no external interface attached. Just the Aggregate.
When I made the edit that I needed to do for the client, consolidated the track, and exported the stereo track from PT to my desktop, the noise was gone when played back. So the actual audio files aren't corrupted, but something is weird in my DAW.
What should I do? Where do I start?
My specs are listed below.
Model Name: MacBook Pro
Model Identifier: MacBookPro9,2
Processor Name: Intel Core i7
Processor Speed: 2.9 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Memory: 16 GB
Boot ROM Version: MBP91.00D9.B00
SMC Version (system): 2.2f44
Old 07-02-2018, 04:31 AM
Default Re: a session recorded in PT10, opened in PT11. NOISE!!!
Let me understand this - no audio interface but you monitored through the internal speakers? Or did you use a pair of headphones?
Was the noise actually in the audio? Or was it mechanical? And the noise was only happening when played inside PT right? When you say 'background noise' could you better describe that? Static? White noise? High pitched/low pitched?
Jack
QAPLA!
Old 07-02-2018, 07:03 AM
Thanks for your response and questions. Let me try to clarify.
I was monitoring in BeyerDynamic 770 headphones. I unplugged them to see if the noise was there in the computer speakers, which it was.
The noise isn't a malfunction of the monitoring, because I've tested them with other sources. I've watched movies on the computer speakers, I've plugged the headphones into other hardware, and they are working properly.
The noise was only happening when played inside Pro Tools. It sounded like digital distortion.
Old 07-02-2018, 07:40 AM
no interface. I was monitoring through headphones (Beyer Dynamics 770d), and then checked it with the computer speakers.
The noise was only in PT, because I exported the stereo audio track I was working on and played it back in iTunes and it sounded fine.
The noise was best described as digital distortion. Not high pitched.
Old 07-02-2018, 10:42 AM
Those Beyers must really be efficient because the headphone output on a Mac laptop doesn't have a whole heck of a lot of drive behind it. Try running that PT session through a real pair of powered monitors and see how that sounds.
Jack
QAPLA!
PT Crashes while importing PT10 session to PT11 Monicahe Pro Tools 11 1 05-28-2016 08:45 AM
Session opens in PT10 but not in PT11 - Playback Engine does not support... DC-Choppah Pro Tools 11 2 03-15-2014 03:07 PM
Recorded MIDI drums (Abbey Road) - file is still there when re-opened but won't play cio-cio san MIDI 0 07-10-2011 03:54 PM
Recorded in 7.4 can it be opened in 6.4? MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-23-2008 06:24 PM
Can a 5.3 session recorded with HD system be saved as 5.1 session and opened on mix s Ricky Cobble General Discussion 0 02-03-2003 02:10 PM
