Old 10-10-2015, 06:34 PM
QaliStacks's Avatar
QaliStacks QaliStacks is offline
Default Can't import audio (Assertion Error) with Pro Tools 11 on El Capitan/later
I've upgraded to OSX el captain and am finally getting around to setting up a new session and keep running into this error when importing audio:
Could not complete the Import Audio command because Assertion in "/Volumes/Development/151228/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559.
(Use the Copy button to copy this message to the clipboard.)
Is anybody else had this issue? And if so how did you solve it?
ADMIN EDIT: http://avid.force.com/pkb/articles/e...rt-Audio-Error
Old 10-11-2015, 07:48 PM
Post Re: Importing Audio issues
Yes.
Drag and drop instead of the Import Audio command.
Old 10-11-2015, 10:30 PM
QaliStacks's Avatar
Default Re: Importing Audio issues
It worked thanks
Old 10-24-2015, 04:36 AM
L-studio L-studio is offline
It worked thanks
For me too. Thanx!!!
Old 11-04-2015, 06:18 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Default PT 11.3.2 on El Capitan... can some people chime in?
Who all is running 11 on El Cap?
Please specify PT11 version (Vanilla or HD, #.#.#, El Capitan 10.11.x) - and issues present
I am trying to identify wether people are running ok, or if everyone is having issues.
And, if anyone is running ok, what versions and machines - so I can chase down the issues I'm having.
I am on PTHD11.3.2, on El Capitan 10.11, MacBook Pro 13" Late 2011, Import Audio Assertion Error
MacBook: https://support.apple.com/kb/SP645?l...ewlocale=en_US
If you need to find your machine info, click the Apple Icon, About This Mac, Support, Specifications.
I would like to take my production machines to El Capitan, but my testing on my MacBook is exhibiting Import Audio Assertion Errors, and I'm unwilling to live with that. Soon, I may make a production machine system clone, and try it, but I'd like some feedback first (I know we will see Eucon issues as well, at least with scribbles)
Thanks!!!!!
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 11-05-2015, 07:43 AM
Eric Lambert's Avatar
Default Re: PT 11.3.2 on El Capitan... can some people chime in?
PT12 isn't even El Capitan ready, and PT11 was designed with Yosemite in mind, so be careful playing with fire. I'd suggest jumping up one from where you are -- into Yosemite -- but not up two.
Actually, in retrospect, I think Mavericks might have been more stable with PT11 than Yosemite is. Some days I regret upgrading.
Old 11-05-2015, 07:51 AM
All our production machines are on Mavericks 10.9.5
I will not move any production machines to El Capitan until I've exhaustively researched and tested.
The main reason I want to move them to El Capitan is for Metal ... Especially for the two machines also running Final Cut Pro X.... and there are also overall performance increases. El Capitan is feeling faster across the board on the MacBook Pro I am testing it with.
I do not want to move to 12 at this time. In reality, our systems are rock solid on Mavericks, and I will not move them away from 11 on Mav unless I am able to do so reliably and with performance increases (mainly for the video side of things)... that's the whole point. There is really nothing in 12 that interests me, and I'd rather not give up licenses to move to it....
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
Old 11-11-2015, 01:09 PM
stacyparrish's Avatar
stacyparrish stacyparrish is offline
This "work around" worked for me as well. BUT! what is the fix for the problem? Drag and drop as an import method in Pro Tools is not going to work for me for very long....
Cheers
Old 12-09-2015, 01:06 PM
Bill Pool Bill Pool is offline
You may need to upgrade Pro Tools to version 12. Pro Tools 11 isn't compatible with El Capitan.
http://avid.force.com/pkb/articles/C...tibility-Chart
Old 12-15-2015, 10:24 AM
auragami auragami is offline
Default Import audio error message
When I attempt to import audio, I get the following error message:
Could not complete the Import Audio command because Assertion in "/Volumes/Development/153787/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559.
I'm on a 2015 Macbook Pro, El Capitan 10.11.2, running PT 11.3.2, my interface is an Apogee Duet.
Thanks in advance,
Michael
Any ideas how to fix this error during audio import: Assertion... line 603. luism Pro Tools 12 3 03-14-2018 11:36 PM
Pro tools 9 assertion error cannot import any data blazinbk Windows 4 04-30-2012 06:52 PM
Can't Import Audio from QuickTime Video -- Assertion Error David Ziegler Pro Tools 9 28 09-18-2011 04:09 AM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
