Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 10-19-2019, 06:32 AM
BenzoSt2 BenzoSt2 is offline
Default how to I get xpand2 to work with imported tracks?
I imported a MIDI file with 16 tracks that I previously created and exported on another computer using Pro Tools M-Powered.
When I insert Xpand2 to a track, the track remains gray instead of turning blue. And I can't get any sound to play from the tracks that I inserted Xpand2 upon.
Benzo Stanbury
Old 10-19-2019, 08:14 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: how to I get xpand2 to work with imported tracks?
Its not clear from your description exactly what you did. Not sure what you mean by the track "turning blue". In any case,make sure you have Xpand instantiated on an instrument track, not an audio track. Then on one of the MIDI tracks, make sure the MIDI track output is directed to that instance of Xpand.
I assume you have 16 different parts, hence 16 MIDI tracks. With Xpand, you can have up to 4 different parts, each on its own MIDI channel, so at minimum you would need 4 instrument tracks each with Xpand on it. You will need more if some of the Xpand sounds you want to use are layered using more than 1 voice slot in Xpand. Just be sure you've got the right MIDI channels assigned for each instance of Xpand and the MIDI outs for all the MIDI tracks. Hope that helps.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Imported Tracks Disappearing ! epiphone Pro Tools 12 5 11-12-2015 11:51 PM
Imported WAV tracks out of sync Aster Windows 6 03-15-2014 02:12 PM
I Imported stereo tracks , but PT reads as 2 L&R Mono tracks ? Seafoam_Green Getting Started 9 02-01-2014 09:29 PM
mastered tracks imported from cd are WAY hot! tioshi Pro Tools 10 15 12-01-2012 02:50 PM
Can't fade imported tracks Kevin Withers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-16-2009 06:57 PM
