  #21
Old 10-19-2019, 08:55 AM
jasonkalman jasonkalman is offline
Default Re: Please Help Me Upgrade My Old TDM Rig
Originally Posted by ProTooler View Post
Thank you JFreak, the.engineer & Darryl Ramm for responding. I really appreciate you guys helping me.
I guess that I’m afraid that if I lose my TDM processing, I won’t be able to mix big sessions or track without noticeable latency with a native system. I would define latency as “noticeable” latency. Once things start sounding phasey in the headphones, it’s hard for me to look at the drummer or singer and tell them to just deal with it. I don’t get any noticeable latency with my TDM system unless I have a big native plugin on my master bus.
I read compatibility specs and I’m finding that most new plugins require a higher version of PT and Mac OS and aren’t supported on my system.
I also need longer delay compensation. I can’t run a big native plug like Slate VTM without getting into the red.
From what I understand, only 4 GB of ram can be allocated to PT 10. I was under the impression that PT 10.3.8 was as high as I could go without my rig "blowing up”. So, even though I have 10 GB of RAM in my computer, I’m only using 4 of them for PT.
Can a current native system perform as well as my old TDM system when it comes "noticeable” latency and plugin processing? I'm so used to using mostly all TDM plugins, loading up those TDM chips and everything runs just fine with no errors. Admittedly, I’m ill-informed with what native can do these days. If I can get by without having to drop the $4500 on an HDX card, I’d be ecstatic.
Regarding my interface: I was also under the impression that my blue 192 interface would not be compatible with a newer version of PT. Am I wrong?
Thanks again you guys!!
Buy a used hdx card. Actually buy used everything. Hdx will get you .7 rtl. Translation, no noticeable latency
Pro Tools 2023.3 Ultimate, Omni, I/O, Pre, HDX, iMac Pro, OS 12.6.5
https://soundcloud.com/jason-kalman
  #22
Old 10-19-2019, 09:15 AM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by jasonkalman View Post
Analog has latency. Just because the speed of light is relatively fast, there is still latency. I mean if you had a cable say 186,000 miles long, you would get a full second of latency. Better to stick with hdx and smaller cables for less latency than analog!
Sure, I like to run my cables several times around the world to reach the box one meter away
Janne
  #23
Old 10-19-2019, 09:31 AM
ProTooler ProTooler is offline
Originally Posted by Darryl Ramm View Post
Blue 192 today runs fine with all DigiLink systems and all newer versions of Pro Tools.
If I understand you correctly, I'll just need to buy the DigiLink ($299) license?
What *exact* model code/EMC is your Mac Pro? Do you have a Metal compatible GPU? (You can find all you need to know online about upgrading a Cheesegrater to Mojave).
I think the EMC is "2314-2*"
I'm not sure how to tell if my GPU is metal compatible. It's the original graphics card, so I'm assuming no. James has this one: "AMD Radeon RX 580 8GB". I guess it would just replace my current graphics card and then I'd be Metal compatible? :)
Thank you for your help!
Have a great day.....
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Mojave with 64 GB RAM
PT Ultimate (2019.10)
Motu 16a
C/24 Control Surface
  #24
Old 10-19-2019, 09:32 AM
Do you do stand up comedy as well?
  #25
Old 10-19-2019, 09:35 AM
So just an HDX "core" card?
Thanks for your help!!
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Motu 16a
  #26
Old 10-19-2019, 09:38 AM
JFreak's Avatar
All HDX are "core" cards if you want to think about the old concepts
Janne
  #27
Old 10-19-2019, 09:41 AM
Just buy a card if you want to go HDX, used or new. There really is no "core" card, there is only one type of card. Avid persisting with the "core" naming is a little confusing.
  #28
Old 10-19-2019, 09:57 AM
Thank you!
Trying to get up to speed here shows me how far back in the dark ages I am!
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Motu 16a
  #29
Old 10-20-2019, 02:30 PM
the.engineer the.engineer is offline
Originally Posted by JFreak View Post
Catalina is out already
Shows how behind I am
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #30
Old 10-21-2019, 07:56 AM
ProtoolsLover ProtoolsLover is offline
Sounds to me like you should stay TDM.
I bought mpowered 7.4 with free upgrade to ver 8. HOW DO I UPGRADE cmangeot Pro Tools M-Powered (Win) 4 02-21-2020 04:18 PM
Missing 1 qualifying license(s) for upgrade to Annual Upgrade Plan for Pro Tools 12 bangmusicdk Licensing & Accounts 0 11-12-2016 10:27 AM
Pro Tools Upgrade Upgrade Plan Extenstion adam79 Pro Tools 12 3 04-30-2016 10:07 AM
Upgrade question - can I use mbox2 micro upgrade on 002 system? spreston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2009 11:22 AM
5.1 upgrade..drivers? also is the D-verb demo an upgrade? bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-21-2002 11:46 AM
