Old 11-04-2018, 10:16 AM
Capsuletta Capsuletta is offline
Default Re: Hdx do not work!!! **!%
Originally Posted by Darryl Ramm View Post
Look for system preferences>privacy & security issues, they are a cause of problems exactly like you are describing.
Did you get pop ups during install that needed approval that you missed?
And check this (even though that article is for High Sierra) http://avid.force.com/pkb/articles/e...h-Sierra-10-13
no, there was no problem during the installations. I checked the security and no zero messages.
Capsuletta
www.legrenierstudio.it
Mac Book pro (I7 - 3,1GHz - 16gb Ram)
OS Sierra
Pro tools Ultimate 2018.10 HDX
Old 11-04-2018, 10:17 AM
is there a way to update the firmware if pro tools do not recognize the card?
Capsuletta
OS Sierra
Old 11-04-2018, 11:30 AM
You are likely to dig yourself into a deeper hole farnarkling around with firmware. Unless you have reason to know you need to upgrade leave it alone.
Kext related security issues at keast on High Sierra are likely to cause all the thigns you describe. Are you sure you are on Sierra (10.12) not High Sierra (10.13).
But either way check...
Is the driver kext file even there? (/Library/Extensions/DigiDal.kext)
Is the kext loaded into the kernel? ("kextstat | grep Digi")
If not did you try force loading the kext?
And are there any errors in system.log or similar (see Console.app).
And if you had a kext related error on install it's gone now. I think they persist for 30 minutes or so. You can uninstall the drivers (and heck Pro Tools as well while you are there) and try reinstalling it with nothing else running and no other windows blocking your screen.
Have you ever seen the HDX card work? Is it new or used? Can you test it in another system?
I have no clue about powering the HDX card in the expansion chassis you are using. Is the internal power cable connected to the card? Supplying power (ideally measure the voltage and current at the card end of the cable with a multimeter.
And if all that does not work and nobody else has any other ideas I would grab a spare drive/partition do a full clean Sierra install on it (maybe a recover to that from an existing Sierra recovery partition) and then install the minimal ILM, driver and Pro Tools software just to see if that works.
And/or time to contact Avid support or your dealer.
Old 11-04-2018, 03:53 PM
yes I have sierra, I'm not crazy !!
the card works, first thing because the mac recognizes it and second thing because the lights are green both forward and back.
The card is used is not new, that's why I refer to the firmware, tomorrow I go to the studio by a friend of mine and I try on another system
Capsuletta
OS Sierra
Old 11-04-2018, 04:22 PM
The Mac “recognizing” a card (like in the system profiler seeing it) just means that some of the PCIe interface chips and a PROM or similar chip with an ID number in it are working. Which tells you little in terms of the actual operation of the card... a device driver actually loaded and not spewing errors hopefully tells you more. So again, simple obvious question: is the driver (kext) actually loaded for the card? If not what happens when you force it to load (the instructions I gave posts ago)?
What the LEDs actually mean, I have no idea. Does anybody?
  #16
Old 11-05-2018, 02:01 AM
I tested with a working system, the sonnet works, even the avid I / O converters recognize it, in fact they remain with the orange lights of non-sync.
I come to think that it is really the card that does not work.
are there any other possibilities for control?
Capsuletta
OS Sierra
  #17
Old 11-05-2018, 02:38 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
Originally Posted by Marco Bernardo View Post
ps: I just remember this!! Did you try to RESET the HDX card?
http://avid.force.com/pkb/articles/e...t-HDX-firmware
Sorry for double posting but I didn't saw your answer on this one.
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
  #18
Old 11-05-2018, 02:40 AM
I tried but it does not work, I really do not know what signals it should give me
Capsuletta
OS Sierra
  #19
Old 11-05-2018, 06:00 AM
TOM@METRO's Avatar
Perhaps this has Already been mentioned, but have you tried to run Digitest on this card?
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.6 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #20
Old 11-05-2018, 06:04 AM
yes but if the card is not detected, even the digitest sees it.
what are the chances that the card will not work even if it is detected in the preferences?
Capsuletta
OS Sierra
My Pro Tools does not work! I can't get it to work with iLok jarred89 Licensing & Accounts 19 11-08-2016 12:27 PM
Next Victim - Artist surfaces do not work with PT11 but work fine with PT10 jimmyjayp Artist Series 10 12-29-2014 03:38 PM
Mackie Universal control Pro only work with protools11 dose not work 10.3.9 why??? sayed mohammed Windows 6 11-11-2014 08:22 PM
Audio Suite plugins that work in 10, do they work in 11? David Sandwisch Windows 1 08-10-2013 08:14 PM
How does Direct Connect work?? (Does it work well??) tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-18-2001 08:13 AM
