Old 06-09-2016, 12:38 PM
wynnsong wynnsong is offline
Default Pro Tools 12 Missing CODEC
Hello,
I recently purchased Pro Tools 12 on Windows 10, and as soon as I import a video, an error message pops up saying " "Unable to link to file "<file name>" due to either a missing CODEC or the file may be unsupported"
Video Engine is installed, and Codecs LE are installed. However, when I double check the Application Manager, the Codecs LE gives the "install" option. Even when I re-install by pressing the button, it goes right back to "install". Could this have something to do with it?
The video files I am importing are standard .mp4 and .mov files that do not have several Codecs that could interfere with Pro Tools importing procedure.
Anyone have experience with this issue?
Thanks,
Wynnsong
Old 06-09-2016, 01:33 PM
Extreme Mixing Extreme Mixing is offline
Default Re: Pro Tools 12 Missing CODEC
I had missing codecs too. I just bought a little program called VicConvert for $8 that seems to fix this easily. But I'm on a mac. Must be something similar for Windows...
http://www.reggieashworth.com/vidconvert
Steve
Steve Shepherd
Extreme Mixing
Old 06-09-2016, 03:54 PM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Have you got Quicktime installed?
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB - 2 x Internal WD Blacks + MSATA card - Davinci Resolve 16.0b7 - Canon HF G40
Old 06-09-2016, 04:08 PM
Yes. But I can't find my license for Quicktime Pro 7. This little app seems better and faster than quicktime ever was!
Steve
Steve Shepherd
Extreme Mixing
Old 06-10-2016, 02:02 AM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
Originally Posted by wynnsong View Post
Hello,
Thanks,
Wynnsong
More than likely you are trying to use an Interleaved video file format. You need to use a container format for Pro Tools. .Mov or .Mp4 should solve this issue. You will need to convert it. Handbrake is free and can most likely do this for you.
Sign up for all things....AWESOME!
Kris
May the music move you
Old 10-16-2016, 08:11 AM
eyesack eyesack is offline
Has this been solved? I'm having the same issue.. Also on Windows 10 trying to import .mp4 and .mov files not using multiple codecs. Getting the same error message as wynnsong.
Application Manager is telling me Codecs LE is installed but looking in Program Files (x86) --> Avid --> Avid Codecs LE it is EMPTY. I've tried uninstalling and re-installing Codecs LE but it did nothing.
I have quicktime installed but only installed it after installing Pro Tools 12. I read somewhere that this can cause problems.
Any ideas?
Old 12-27-2016, 11:08 PM
dropctuned dropctuned is offline
Same problem.
OF COURSE, the video engine is enabled.
Tried dv25 mov , h264 mov but to no avail.
The only temporary solution is to create gigantic DNxHD files.
Yes, quicktime is installed (7.7.9)
Yes, it was installed before Pro Tools was installed.
Any non generic answers, anyone?
Old 12-28-2016, 10:16 AM
Ed Douglas's Avatar
Ed Douglas Ed Douglas is offline
Originally Posted by dropctuned View Post
Same problem.
I get this intermittently in sessions that have previously opened without issues. I use ProRes Proxy (fully supported) files almost exclusively. Every once in a while upon re opening the session, I will get a missing codec error. I simply highlight the existing video file and re import it with the import video command. The video engine restarts and it all works again.... until the next time it decides to be ornery.
Are you able to try ProRes? I use Compressor to make ProRes copies when I receive h264 files.
Sometimes you may have the codec installed, but ProTools has a brain seizure and reports that you have an unsupported file even though you do. Nice job, Avid.
E>
Neotech Concepts
http://www.imdb.com/name/nm0235036/
! sonic gymnastics for the illusionary arts !
2019 i9 MacBook Pro (15,3), macOSX 10.14.6, PT Ultimate 2019.6, Atmos Production Suite 3.2, MDA Creator1.5, Rx7 Advanced, Ozone 8 Advanced, Kontakt 6.1.1, Soundminer v4.5Pro, Spanner 3.0.5, SoundHack 0.896
EuControl 19.9.1.17, PT|Control 19.9.1.17, iPad Pro 12.9" gen 1, iPad Pro 12.9" gen 3, Apollo 8 Duo tb2, UAD-2 Satellite Quad tb2, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 4 28TB
Old 04-21-2017, 06:48 AM
mdb mdb is offline
Let me chime in here.
When I drag a video into a brand new latest Pro tools 12 install on a brand new clean installed win10 pro 8 core PC with RME interface, Pro Tools freezes up for about 20 seconds.
After that, I get the import options and press OK. Then Pro Tools freezes for another 30 seconds.
Then I get an error message "unable to link [blah blah] due to either a missing CODEC or the file may be unsupported".
Alternatively, nothing happens on import. No video, no message, just back to Pro Tools. This is just random.
When I choose file > import, the same thing happens. With the alternative scenario beeing that I'm left with the import screen after a 20-30 second freeze up. No message, nothing.
The video's play fine in Quicktime and are used in my current Win7 PT10 setup.
Codecs LE (whatever that's supposed to mean) is installed.
Forum search only reveals identical problems with no solution.
AMA plugins? Really? Just make the video work before starting to brag about:
"A revolutionary plug-in architecture that greatly accelerates your file-based video workflows."
OMG LOL
UPDATE:
The problem seems codec related. As in PT10, any codec other than Avid's own STILL seems to have playback and/or import issues.
I have no idea what benefit the new 'video engine' is supposed to have, as it only seems to introduce more problems and a more complex workflow.
Looking at Adobe premiere for example, that can even edit raw DVD *.vob files, one starts wondering why Pro Tools can't even import and play a simple H264 file properly.
So still, after all these years you're bound to converting the videos to Avid codec (that only Avid uses) to minimize problems.
But finally full screen! Hurray!
How to find out what codec i'm missing? andreasfromsweden macOS 2 11-04-2014 01:07 PM
Missing codec helloo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-07-2006 05:23 AM
Quick Time Movie Fails to Import Missing Codec Sitruc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-09-2005 11:45 AM
Avid Codec missing h1ntOn Post - Surround - Video 6 04-07-2005 08:01 PM
troublesome bouncing- > .wav to wmp missing codec? Mariachi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-02-2004 09:12 AM
