Old 01-03-2009, 10:22 AM
drewlyddon drewlyddon is offline
Default Axiom 49 midi recording issues
Whenever I try to record midi using my Axiom 40 keybaord, it doesn't record it properly. It only seems to record a "note on" bit, shows the duration, yet when playing back only plays the "notes on" bit (like really short stabs even though the duration may be 1bar, maybe 2!!!!
I think I've tried every single option in the peripherals, MIDI studio, Input filter, Input Devices... everything and still something is not right!
It's plugged in via a USB cable directly into my machine, and when playing it plays perfectly (note duration etc...), its just when recording it does this, and its really annoying and time consuming!!!
If someone could shed some light on this ASAP I would be very very grateful!!!
Thanks,
a midi noob: Drew.
Old 01-03-2009, 10:40 AM
RussUK RussUK is offline
Default Re: Axiom 49 midi recording issues
Here's the answer http://airvirtualinstruments.blogspo...es-in-pt8.html
I work with amazing people who do amazing things.
Founder of the Expert Sites.
Old 01-04-2009, 01:10 PM
rodneyruger rodneyruger is offline
i had the same issue unfortanatly that vid didnt help out at all....but it seem like the problem was the settings within the axiom49 i had more than 1 zone enabled and it sent midi from both channels....if u have default presets installed on the axiom
1. go to preset 15...
2. press the zone range button on the axiom
3. select disable zones 1 & 2 and enable zone 3 (all u have to do is pres the 3 buttons under the faders)
4.while zone 3 is still flashing pick zone pres ur c1 key then press ur c5 key and press zone range button again to stop zone 3 from flashing
5. then record some midi u should see the double notes are gone now which was causing PT to play and stop quickly and u dont have to ...worked 100% for me
p.s. u dont have to use preset 15 but it alredy has the tranport controls set up to save u time u can stll use ur zones just make sure they arent triggering on the came octaves or ur going to have to transpose them
Last edited by rodneyruger; 01-04-2009 at 01:16 PM. Reason: forgot to say u dont have to use preset 15
Old 01-04-2009, 01:51 PM
Thanks - would you mind if we add this solution to the blog?
Old 01-04-2009, 07:02 PM
pguy pguy is offline
Drewlyddon..... I think that's the same issue I'm having.
Does that first note precede a longer note and have an X" on it?
Axiom 61 Issues knen808 macOS 0 07-07-2011 01:23 PM
Issues with Pops and Clicks when recording midi in PT8.0 Hank Chinaski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-16-2009 09:17 AM
Axiom 49 instrument midi issues Artfuldodger MIDI 8 08-13-2008 03:36 PM
issues with playback/recording with midi controller freezegelman MIDI 4 11-15-2007 10:44 AM
MIDI recording issues 2A Batterie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-08-2004 02:07 PM
