Old 05-31-2004, 12:04 PM
digitum digitum is offline
Default Antares filter
i have download the soft Antares filter and i try to make it work..
I donwload the rtas version for window xp
I create a aux stereo track. Select the Antares filter as plug in.
Then i create a midi track.
Select the Filter as instrument
Press the record ready button..
it does not work
Same setting works for Sampletamk or Reason
Is there a setting im missing?
In the filter plugin/factory settings, if i select the patch beat/Flangefollow, i heard a little of signal but that s it....
Protools 6.4 LE
Window XP
Digi002
Thanks
Old 05-31-2004, 01:24 PM
skylab001 skylab001 is offline
Default Re: Antares filter
I usually use Filter as an Insert on a track, I usually set the beat clock to transmit to filter and then do all my settings in filter. If you are trying to get filter to respond to Midi CC's from your midi track then you have to set up Filter to respond to those CC's in the Control section on the top right side of the Filter window. Didn't the download come with a PDF manual....it's got all the stuff in that. When you get in going you'll love it!
Good Luck
Any good Filter / Step Filter Plug-ins? Jsswtpmp182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-07-2006 05:01 PM
Q about Antares Filter ejwells 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-20-2005 03:05 PM
pop “filter” Fritz Tips & Tricks 3 12-03-2003 08:28 PM
antares filter..... jsmooth226 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 11-22-2003 07:05 PM
NEW Antares filter RTAS demo Orleanska 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-16-2003 03:42 PM
