Old 11-19-2018, 02:44 PM
khoop2112 khoop2112 is offline
Default Re: 2018 MacMini experiment on ProTools HDX
Sonnet echo express pro - TB1.
I've been doing many tests today trying to track down why I get the 9173/6101 error messages.
Last night I brought the session that had been stopping, and ran it headless on my MacMini with no eGPU, and no HDX/UAD cards. It looped for 45 minutes and never stopped.
Today I brought the mini back down to my studio, and tried the test without UAD or HDX, and it still stopped. Then tried with HDX/UAD but no eGPU, and it stopped.
Then I lowered my resolutions from 2560x1440 HiDPI on my 2 monitors to 1920x1080 HiDPI, and worked fine without stopping but no HDX or UAD. I'm a little perplexed to be honest.
Will keep testing but open to any thoughts on things to try...
Old 11-20-2018, 02:46 AM
Ru_C Ru_C is offline
Thanks for all this testing. Just to be sure, was there a combo above that included the HDX card but removed the eGPU?
I'm watching this thread carefully, as the 2018 Mac mini+eGPU is likely to be many folks Mac Pro replacement , but i'm uncertain if the eGPU running via thunderbolt3 will restrict the operation of HDX/HDN connected in the same way. cheers
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 11-20-2018, 09:47 AM
Carl Lie Carl Lie is offline
So after it worked with lowering the resolution did you try with the HDx and UAD? Sorry if that's what you mean above but just checking.
Agree many of us want to know what a cost effective replacement will be. I replaced my MP with another (secondhand) and feel like I have some time but your tests are helpful. Also curious of the track count and if any instrument tracks are being used in the session.
Thanks for all the info you're giving us!
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 11-21-2018, 07:11 AM
LukeHoward LukeHoward is offline
FWIW, my 2010 MP with a RX480 has definitely struggled running Pro Tools at 4K HiDPI resolutions.
https://lukehoward.com/
Old 11-21-2018, 12:21 PM
Scott Stillwell's Avatar
Scott Stillwell Scott Stillwell is offline
Stillwell Audio
The boot drive on the Mini is FAST.
Yeah, it sucks that it's soldered on and non-upgradeable, but at least it's NVMe flash, which screams. I recently bought one for a build automation server, and it's so much faster than the 2011 Mini it's replacing that it's not even funny. Runs significantly cooler than the old model, too, except when a build is actively running (which pegs ALL cores at 100% until done).
Gives me at least SOME hope that the new Mac Pro will be worth having whenever it actually shows up.
  #16
Old 11-21-2018, 09:01 PM
Yeah - I need to investigate how much of the sluggishness can be attributed to my 4k 65" TV. I did pick the TV with the lowest input lag but I know it's still not nearly as fast as a pure computer monitor. My other 32" 4k monitor is situated for my programming station, so I typically use Logic while on that monitor, I'll try some tests using PT.
  #17
Old 11-22-2018, 03:50 AM
::F-L-E-X::'s Avatar
::F-L-E-X:: ::F-L-E-X:: is offline
Interesting thread...
Khoop - wondered if you've considered or tried an alternative to the Blackmagic eGPU? Seems like something like this would work in your Sonnet Echo :
http://www.macvidcards.com/store/p11...Pro_6%2C1.html
Although this solution seems to be aimed at the nMP 2013, can't see why it wouldn't work with the TB3 Mini also?
www.fluidity-studios.net
  #18
Old 11-22-2018, 07:44 AM
My Sonnet is a 2 slot, and currently has HDX and UAD cards so it's all full.
Blackmagic does make a higher end eGPU with the Vega 56 card as well. If I end up deciding to keep the MacMini rig, then I might explore some more powerful video card options. So many variables right now in making sure the Mini is a viable, stable replacement for the 2013.
  #19
Old 11-22-2018, 09:32 AM
StratoBobster StratoBobster is offline
it would sure help to "unmuddy' the water if there was a supported version of Pro Tools for Mojave right now.
  #20
Old 11-22-2018, 09:16 PM
Exactly.
Which CPU / computer for protools 2018 boitason Pro Tools 12 19 11-13-2019 11:58 AM
ProTools 2018.4 won't launch planck Pro Tools 2018 6 08-27-2018 04:54 AM
S5 Fusion with ProTools 2018 tricklabot System 5 6 08-27-2018 01:48 AM
ProTools 2018.1 PTPerson ICON & C|24 4 02-19-2018 01:08 PM
I just tried a SRC experiment; dkrausz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-11-2002 06:59 AM
