Old 09-23-2019, 11:45 AM
Kdrums Kdrums is offline
Default S3L-X - Locking up - On-Stage App
I have been having what appeared to be random "locking up" of S3l-X system lately. After troubleshooting at a few shows/studio I think I have replicated what is at least causing the failure. With that said, let me break down the situation.
Symptom: Console locks up as in ( I lose all control of Surface and ecx/i pad control. Touch screen is also locked out as well as direct mouse/keyboard. The engine/stage boxes still pass audio but the peripherals will not come back online without a full re-boot of engine.
I have narrowed this down to symptom happening only when the I-Pad is connected and operating. It takes anywhere from 1-2 hours before it starts, sometimes sooner. After re-boot it will continue to run but has known to happen again. I have disconnected I Pad and wifi and cannot get system to fail.
I am running 4.6.1.4 Venue software
VENUE On Stage Version 1.3
Thank you...
Old 01-14-2020, 04:14 PM
channelaudio channelaudio is offline
Default Re: S3L-X - Locking up - On-Stage App
I am also having this same freeze up issue. If you have figured it out please let me know as I have a gig coming up soon!
Old 01-14-2020, 04:24 PM
I did figure it out. The problem was an IP address conflict with router/Ipad. Make sure you use a static IP and do not use DHCP. Problem solved for me. I should have know better
Unit has been rock solid since.
Good Luck!
Old 01-20-2020, 06:15 PM
I found that it was a network conflict. I was using DHCP. Try using a static IP.
Old 02-11-2020, 01:52 PM
RyanJ's Avatar
RyanJ RyanJ is offline
I was about to suggest that it may be related to your network switch using an auto DHCP trying to readdress devices. Try manual?
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
New website for The Dub Stage dr sound Post - Surround - Video 12 02-22-2011 10:37 AM
Question: Auto-locking and Mute locking Charles Deenen Pro Tools TDM Systems (Mac) 1 09-25-2010 01:07 PM
Losing stage link to 2nd stage rack sonicboost VENUE Live Sound Systems 7 11-15-2009 01:43 AM
Laptop on Stage tball 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-02-2005 04:12 PM
OT?Dubbing stage MarcelD Post - Surround - Video 6 11-23-2003 11:01 AM
