Old 10-28-2004, 12:08 PM
tapani tapani is offline
Default how to limit very soft AND loud singer? Knob ride?
I realize I can put a compressor in the signal chain, but is there a simple quality limiter which would not mess the signal chain too much?
Or maybe you guys try to 'ride' the rotary input knob?
I do it with faders, but have any of you developed a good touch to riding the mbox rotary level input knob?
Is there an Mbox compatible control surface with good faders?
Any other suggestions? The singer in question does sudden volume changes. Otherwise I would record the loud bits separately.
How about recording to two channels (using two mics or a Y cable) at the same time with differing input levels? One loud for the quiet bits and not caring about distortion or spittiness and the other channel quiter and later combining them?
tapani
Old 10-28-2004, 12:16 PM
Third Eye Studios Third Eye Studios is offline
Default Re: how to limit very soft AND loud singer? Knob ride?
The Y-cable suggestion doesn't sound too bad. It would be weird knowing that you were recording severe overs, but what the heck. Personally though, I would just set the level to not go over on the loudest parts and compress it or automate volume later. The command 8 has good faders to answer your other question.
Third Eye Studios.org
Old 10-28-2004, 12:23 PM
lemix's Avatar
lemix lemix is offline
tapani ,
What a great question dude...
In he "old" fully analog days we had a few different options, one being the multi -mic approach as you've mentioned. Also sometimes engineers were riding input faders on the console, following charts and a predictable, pro vocalist. But, lets not go there...
In your case, and IMO the simplest way to do it is; set the channel gain for the maximum level before clipping and just record.
You can automate the track afterward, or chop it into soft and loud parts to apply appropriate processing.
Of course a pro singer with good mic technique is a plus !!
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 10-28-2004, 03:17 PM
rogga_bogga
Guest
Posts: n/a
I found this thread pretty useful:
http://recforums.prosoundweb.com/ind...48/0#msg_15148
Old 10-29-2004, 11:36 AM
what a great thread! with guys like george massenburg replying too...!
Thanks rogga boggga!!
Tapani
Old 10-29-2004, 07:47 PM
will the moor will the moor is offline
that two mic thing sounds like a good idea. I've always tried to coach the singer about mic technique. If he wants a good recording, he needs to be willing to learn about the process. if not, call him a sucka and kick him in the knee. then set up two mics...
will
http://soundofthatday.com
Soft knob setting in EQ Trent Nelson Artist Series 3 02-03-2012 07:16 AM
Can't get the crash-ride in BFD lite to sound like at true ride-is this deliberate? studiostrat Virtual Instruments 3 09-11-2008 02:55 PM
Monitor control knob and mute disabled - it's just LOUD!! tpt1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-03-2007 04:08 PM
To Soft-Limit or Not to Soft-Limit? Bambison Pro Tools TDM Systems (Mac) 17 03-27-2004 02:53 AM
How to record a"LOUD" singer? ChaplainPC Tips & Tricks 7 10-28-1999 07:51 AM
