Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 12-13-2020, 01:15 PM
mark.wyllie mark.wyllie is offline
Default HD NATIVE + SSL DELTA-LINK + HD OMNI Interfacing
Anyone know if it’s possible to simultaneously connect the SSL DELTA-LINK MADI with the HD OMNI to the HD NATIVE TB interface so that 64 inputs can be recorded via MADI from the SSL DELTA-LINK whilst using the HD OMNI for 8 analogue outputs for control room monitoring and foldback for headphones? Any latency issues or incompatibility?
Old 12-13-2020, 04:28 PM
Top Jimmy's Avatar
Not possible. HD Native maxes out at 64 total inputs. That’s 16 channels per each primary and expansion slot on each digilink connection. If the SSL is patched to both digilink ports, it takes up all 64. The only way you can get the Omni in there is to plug it into one of the ports on the card and then plug one port of the SSL into the card with the other port on the SSL into the expansion port on the Omni. But that configuration will only give you 48 in via MADI.
James Cadwallader
Old 12-14-2020, 01:42 AM
Default Re: HD NATIVE + SSL DELTA-LINK + HD OMNI Interfacing
Thanks for the clarification with the HD OMNI.
Still using the HD NATIVE TB interface and noting that the SSL has two sets of MADI ports (A & B), might it be possible to record 64 inputs from the SSL (with this patched to both HD digilink ports) plus somehow patch/map another MADI DAC (such as the FERROFISH A16 MK-II) for analogue outputs?
PT INPUT: SSL MADI I/O (A) > HD NATIVE TB > PRO TOOLS
PT OUTPUT: PRO TOOLS > HD NATIVE TB > FERROFISH DAC via SSL MADI I/O (B)
Old 12-15-2020, 11:59 AM
Top Jimmy's Avatar
That will work as long as you only patch the optical MADI output to the DAC. The input would still need to come from your source if you want to achieve 64 ins. SC type optical cables frequently come as pairs, but you can easily snap them apart to route the in side and out side separately.
James Cadwallader
Old 01-24-2021, 03:45 AM
Regardless of which peripheral hardware is configured as described above, is it possible to input/output only 32 channels using Pro-Tools | Standard or is it only Pro-Tools | Ultimate that has the drivers to interface with the HD Native box?
HD Native + HD Omni + SSL Delta-Link + SSL Alpha-Links Plec Pro Tools HDX & HD Native Systems (Win) 7 07-13-2018 01:58 AM
AVID S3 - OMNI IO - SSL Delta Link MADI IO japple Buy & Sell 0 02-10-2017 08:36 AM
Omni! HD Native! Satellite Link! 002R oh my! Ryan Kelly Buy & Sell 2 05-02-2013 09:16 AM
PT HD Native Card + Delta Link and 192D dwaldi Pro Tools HDX & HD Native Systems (Mac) 2 01-25-2012 02:54 PM
Pro Tools Playback Issues at 88.2 with Delta Link / Alpha Link - Any ideas? azirkin macOS 1 01-17-2012 01:30 AM
