Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 11-01-2019, 07:10 PM
bsteeve bsteeve is offline
Default Protools 2019.10 installation fail MacOS 10.13.6
I've tried to install this update but no luck.
Tried both through AVID Link and downloading the update from my avid account.
Direct Download:
When downloading the file directly from my avid account as a .dmg file when I try to open the archive it tells me the file is corrupted. downloaded it several times...
When I go through Disk Utility and open the archive there it mounts but when i try to install it it fails instantly. When I try to copy the protools installer onto my desktop it tells me it cannot be copied but some files cannot be read.
AVID Link:
Files download and open fine but when installing it fails instantly.
Any advice? I'm on High Sierra 10.13.6
Old 11-01-2019, 09:41 PM
_JJ_ _JJ_ is offline
Default Re: Protools 2019.10 installation fail MacOS 10.13.6
Try looking at your System Prefs >> Security & Privacy to see if you need to give permission for the file to be downloaded from an "unknown source" (not the iTunes App store). It may also be asking for your permission to run the installer. If you have either of those issues you should be able to click the padlock on the bottom left, input your user password, and grant those permissions. (This happens in Mojave anyway...)
Old 11-01-2019, 09:51 PM
Originally Posted by _JJ_ View Post
Try looking at your System Prefs >> Security & Privacy to see if you have an option to allow the installer to run. You may need to unlock the padlock on the bottom left and input your user password to give the installer permission. (That happens in Mojave anyway...)
yeah I've checked that already, there is no issue there, I can run the installer but the install fails when the installer starts writing files...
Old 11-01-2019, 09:58 PM
here is the error screenshot that happens during installation
File Type: png Screen Shot 2019-11-02 at 3.52.44 pm (2).png (51.8 KB, 0 views)
Old 11-01-2019, 10:18 PM
finally got this working!! downloaded the file again... not through Chrome, not through Safari, not through avid link....grabbed the link from avid, used that in JDownloader 2 and the dmg file opened and installed no problem.
I have no idea why this worked... but it did
Old 11-02-2019, 04:22 AM
musicman691 musicman691 is online now
So which browser did you use?
Jack
QAPLA!
Old 11-03-2019, 07:18 PM
did not use a browser, copy the link from the AVID website into jdownloader 2, and that worked... strange but it did. Contacted avid and they also sent me a separate link that worked...
Old 11-04-2019, 04:36 AM
jdownloader 2 works without a browser? I've never seen a download manager utility that works outside of a browser.
Jack
QAPLA!
Old 11-04-2019, 05:38 AM
Sardi Sardi is offline
Unless it’s an extension in your browser, that’s how they all work. Stand alone application.
Well, the three that I’ve used in the past were all stand alone. I assume they all are.
2019.10 installation error cmbourget Pro Tools 2019 9 10-31-2019 09:55 PM
ProTools 2019.6 can't work on my MacOS 10.14.4 ClementA macOS 3 10-14-2019 04:36 AM
External Keyboards unreliable on MacOS with 2019.5 TKellzzz macOS 5 06-22-2019 06:24 AM
Pro Tools 8 LE Installation Fail byomaaan Pro Tools SE and Essential (Mac) 3 01-02-2013 12:06 AM
Installation FAIL ayeshe22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 04-20-2010 11:41 AM
