Old 04-26-2015, 03:14 AM
FlorianE FlorianE is offline
Default Destructive Record Bug
I ran into a this bug last week.
I work in audio post, and I like old-school style, so my setup goes:
Master-Bus goes to recording bus plus H/W Direct Out (5.1).
Record Track gets recording bus and goes to H/W Return Out (5.1). And I use Destructive Record mode.
Now suddenly this happens:
When either appending audio at the end of my recorded file, or inserting somewhere in the middle, there is a 2 in 3 chance that the recorded file will be EMPTY (==Silence), although during the recording pass both metering and monitoring on Return Out where OK. The only indication that all is not well is actually the waveform redraw. This does accurately reflect what will be on the track. On 5.1 as well as on stereo.
Workaround is quite simple: stop and try again; third time lucky almost sure.
But who wants to keep staring at the waveform redraw??
PT 11.3.1
OsX 10.8.5
2x2.66 GHz 6-core Mac 32GB Ram
Florian
Old 04-27-2015, 12:23 PM
corym corym is offline
Default Re: Destructive Record Bug
I am having the EXACT same issue. Sometimes it works, other times it doesn't.
PT 11.3.1
OS 10.9.5
Old 04-27-2015, 02:15 PM
Thanks for chiming in!
The crazy thing is that the whole signal path sounds OK all the way.
It seems that the data just are not passed to the file output stream, which instead is writing zeroes.
With a bit of luck, this could be a MINOR BUG...
Forgot to mention:
HDX 2 with a second DA card slotted in.
Old 04-27-2015, 03:03 PM
reichman's Avatar
reichman reichman is offline
I'm seeing destructive punch waveform update problems in PTHD11 and PTHD12, but the audio is always there. My system is fully native, though.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 12-14-2018, 01:58 PM
Felix Rost Felix Rost is offline
Sorry for reviving an old thread..
I have the same issue, Destructive Record and Destructive Punch are recording silence in most attempts. It is only happening when the satellite system (Avid Media Composer) is connected. Disconnect the satellite and it works fine.
It is PT 11.3.1 with HD TDM cards, Windows OS.
Other record modes work fine.
Did someone find a solution for this?
Updating beyond PT11 is not an option at the moment.
http://felixrost.de
How to record to Midi track - Overdubbing instead of destructive record? awritersparadise Pro Tools 9 3 05-07-2011 05:34 PM
Destructive Record dosen't destructively record ! mgauvin Pro Tools TDM Systems (Mac) 0 12-03-2005 10:05 AM
Destructive Record TimNielsen Pro Tools TDM Systems (Mac) 1 07-02-2005 08:36 PM
No destructive record in 6.4? schiffdigital Pro Tools TDM Systems (Mac) 9 04-30-2004 04:05 PM
Destructive record not destructive Mario C Pro Tools TDM Systems (Mac) 4 10-27-2003 04:42 PM
