Search issues in the PT 11 "improved" Workspace
How are people liking the new "improved" Workspace in 11?
The new Search functionality is a disaster, in my opinion. Apparently, they switched the default search engine protocol from a boolean "AND" search to a boolean "OR" search which I think is a huge mistake. For example, if you need to find a "big boom" from an earlier reel, it used to be that you would type in big boom and only files that have "big" AND "boom" would result. Now, any files that have "big" OR "boom" will result. So, in addition to big booms the results will be little booms, baby booms, big winds, big farts, etc, etc. Obviously, this is not useful and is the opposite logic of most search engines (web search, Soundminer, iTunes, etc). Typically, the more terms you add, the more narrow and specific the results should be. Now it is the opposite. Now you get more irrelevant results. You can wrap big boom in quotes and, like a boolean search, you will get only results where big and boom are adjacent, but what if the the file was actually boom big? The new search will not find it. Another missed opportunity is that they neglected to include any other boolean functionality. Instead they added the overly complicated Advanced Search. You have to type in Big, then click on the little Advanced Search icon, then more fields appear. Then, click the + sign and add one term at a time to yield the equivalent of what used to be a simple search (a boolean "AND" search). Anyone else agree that Avid should rethink this? Admin Edit: Idea#4034
Pascal Garneau | IMDb Last edited by DigiTechSupt; 02-06-2015 at 05:19 PM. Reason: Added IdeaScale link -JC |
Re: Search issues in the PT 11 "improved" Workspace
It is a little clunky, but it only takes me 1 second to hit those extra buttons.
It actually seems to work a lot better than it used to. It used to get corrupt databases all the time, and the search was never reliable. I had purchased Basehead to search instead, but now Basehead doesn't seem to work well in Yosemite and keeps crashing and getting corrupted. I'm back to using workspace and it seems to work well. |
I agree you really need to be able to do a Boolean search from the main field. Extra clicking is not efficient.
~Will |
In my opinion, the larger problem is the new reverse logic in the simple search. If you type in bass guitar, you will get bass clarinet, sea bass, and acoustic guitar. Anything with the word "bass" OR "guitar". This is broken and Avid needs to fix it as far as I'm concerned.
The lack of boolean and the goofy Advanced Search is just another example of Avid dropping the ball on a new feature.
Pascal Garneau | IMDb |
It's not the time it takes, it's more the absurd notion of entering one word at a time and clicking that + sign after each word. Standard search logic, like Google or the Workspace in PT 10, would not require this. They changed the basic search function and made it worse.
One step forward, two steps back
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Absolutely! The DUC search might have inspired them.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
I also think so!!
Why can not understand what has changed it. I can not use yet ProTools11 due that. This is a very big problem for a Soundeffect designer. Doesn't everyone use Workspace? The situation for which "or serch" is used effectively can't think of at all. If the situation can't be imagined, Avid should return it to the beginning. |
Another +1 for the Boolean AND Search in Workspace. Prior to PT11 I was able to search my 50,000+ sound effects library, now I will have to invest in a 3rd party system like Basehead or Soundminer. Not impressed. I have started an Ideascale entry on this one. So if you want the AND restoring then please vote for it. Thanks.
Field recorder guide track "select areas to search" doesn´t work | kwassen | Post - Surround - Video | 6 | 04-12-2017 11:53 PM |
"Improved" Field Recorder Functionality in PT10 | simonchase | Post - Surround - Video | 5 | 03-21-2012 06:00 PM |
BRAND NEWBIE HERE: 1st error message - couldn't locate info in a "search" | csrMark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 02-16-2010 02:41 PM |
MIX review of HD: " vastly improved audio" | knewbee | Pro Tools TDM Systems (Mac) | 17 | 02-06-2002 12:56 AM |
I can't "Back" to Search results, after reading a message?? | el biciclista | General Discussion | 0 | 06-15-2001 04:57 PM |
