New structure, strike, transfuser run on PPC
even though avid says no...
these plugs run on ppc I´ve installed them on my other computer (an intel mac, because the installer only runs on intel) and moved the content to my G5, there they work in PT8 the same way as on my intel machine - no problems instead of this - hybrid and velvet only run on intel thought I let those PPC-guys know this cheers
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
Re: New structure, strike, transfuser run on PPC
I can confirm this to be so....
Yes, it works !
I can't get Hybrid and velvet to launch... Do you guys have a workaround ? Cheers, A |
no - unfortunately velvet 1.0 doesn´t run with this iLok authorization, too
Although I purchased the upgrade for use on an Intel Mac, I did try out both the new Strike and Transfuser on my G5 out of curiosity. They will launch and run, but not without some issues. For example, Transfuser always complains its content file is corrupted and that I should reinstall (which, obviously, I cannot since it's Intel only). I also can't seem to switch styles in Strike while maintaining the same kit. Am I missing something? It's not mission critical to have these working on the G5, but it would be nice. I'd be grateful for any suggestions. I'm using 7.4 and 10.4.11 on that computer BTW, which could explain some of the issues.
Powermac G5 2x2GHz 4GB RAM OS 10.4.11 PT LE 7.4 DIGI002r Command8 3xUAD-1 MacBook C2D 2.4Ghz 4GB RAM OS 10.5.8 PT LE 8.0.1cs1 Mbox1 Novation ReMOTE 61 |
strike, structure, tranfuser running without any issues on my G5, so far my experience after 2 weeks - no problems with transfuser content or with changing strike-styles by remaining the kit
I´ve installed the PTIEP on my macmini (Intel) and moved the plugs & content via ethernet to the corresponding G5 folders, but I assume you did that too velvet and hybrid no chance
Well, that's encouraging news! I notice from your sig that you're running PT 8, so maybe it's because I'm running 7.4 that I'm seeing these issues.
Just got the new Transfuser and Strike working properly now on the G5 with PT LE 7.4 and Mac OS 10.4.11.
I discovered you CAN actually run the plugin installer by extracting it from the intel only main installer. You still need to copy the contents by hand, but just running the plugin installer seems to have cleared up all my issues. Thanks for the encouragement. My G5 and I are both very happy! Cheers
May Have spoken too fast on this one.
I can get Strike to audition presets settings but when I try to load the preset it doesn't load the sounds just the preset name. The only way to get the sounds for the preset to load is to navigate from the menu to the plugin-settings folder and load it from there...But the preset parameters don't load correctly. Anyone with a PPC have any answers? All of the strike sound files (1-10) are in the same folder. Thanks Paul |
Did you have o surrender your Hybrid 1.5 Ilok or could the older Hybrid remain working?
PPC 2.7 OS 10.5.8 PT's 8.01cs1 |
FS: Structure, Strike & Transfuser 2.0 | Becharax | Buy & Sell | 1 | 04-24-2015 08:29 AM |
FS: Transfuser & Strike 2.0 | Becharax | Buy & Sell | 11 | 04-07-2014 12:57 PM |
Does Anybody Have Strike 2, Structure 2 or Transfuser 2 In Hand and Working? | Pie Hole Sound | AAX Plug-ins | 43 | 10-25-2013 10:13 AM |
InMusic: Transfuser, Structure & Strike DELAYED! | LightWing | AAX Plug-ins | 14 | 10-19-2013 05:19 PM |
strike and transfuser not working | ilulilu888 | Virtual Instruments | 1 | 08-27-2012 07:36 AM |
