Old 02-18-2021, 12:50 AM
bsteeve bsteeve is offline
Default cascading outputs on master faders not working Protools 2020.12
Hi Everyone.
Shift + Option + Command doesn/t work to cascade outputs on master faders. Mater faders are all at the same width... I swear this use to work back in the day. Any solutions? This is making it a pain to setup my masterfaders output when configuring dolby atmos sessions.
Old 02-18-2021, 01:17 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: cascading outputs on master faders not working Protools 2020.12
Originally Posted by bsteeve View Post
Hi Everyone.
No never been available on a master fader. Only on tracks and aux's.
A master fader is specific to one source
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-18-2021, 07:51 AM
A Master Fader is not an output, it's a hook into a summing node.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24, 3xS1/Dock.
Old 02-18-2021, 11:53 AM
Hey guys.
Let me clarify why I'm asking this question here. When mixing in Dolby Atmos you often have to create 100s of master faders for all your beds and objects to essentially do 2 things, mirror your bus processing onto the object path (especially useful when toggle tracks between beds and objects) and secondly to easily control the level going to the renderer. The big advantage of using master fader is that it doesn't count toward your voice count...
Recently avid increased the number of master faders that could be created for this very reason I believe hence why I'm asking if cascading the "output" selector on master faders possible because doing that manually is a real pain and it seems strange that they would have omitted this.
Old 02-18-2021, 12:34 PM
LDS LDS is offline
oh golly. This is a pretty simple request that really should work. Create 30 mono outputs in a new I/O list, then create 30 mono channels and 30 mono master faders in the session.
Shift + option + command will allow you to assign outputs 1-30 across the channel faders very quickly. But you will need to manually assign outputs 1-30 across the master faders one by one.
Needing to go through 30, 40, 118 mono master faders for an Atmos mix to assign their outputs one by one is a major dent in Pro Tool's otherwise quite speedy workflow. It surely is a bug?
littledevilstudios.com.au
Pro Tools Ultimate 2020.5. OSX 10.14.6. HDX1. DAD DX-32R. DADman 5.3.4.2. Mac Pro 2013. 10 Core 3.0gHz. 64Gb. 4x mSata SSD Drives + 4x HDD. AJA XT IO. Sync HD. Dobly Production Suite 3.4.
Old 02-19-2021, 09:51 AM
OH, sorry - I misunderstood the question. Yeah, hadn't noticed this but cascading multiple master outputs in one go doesn't work and don't see why it shouldn't. In fact, doesn't seem like master faders obey *any* of the usual multi-selection tools work with masters (shift-opt de-assign for example).
Don't remember if this ever worked - would be curious to see if it works on PT12 for example - but this might be a bug.
Old 02-20-2021, 03:03 AM
LDS LDS is offline
I’m not sure it ever worked either. It wasn’t until I started using DAPS that the need for so many master faders came up. In any case, Avid have said it is a bug - PT-221468 "Master Fader Multi-Assign (cascade) not enabled"
Old 02-20-2021, 02:36 PM
reichman's Avatar
reichman reichman is offline
Thanks! Glad to know it's logged. I just assigned 34 mono master faders and my wrist hurts.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 02-20-2021, 04:07 PM
Nick Camaron Nick Camaron is offline
Location: Somewhere in the vicinity of Alpha Centauri, MW
Indeed. I was thinking what a slapdash coding. From experience I‘m afraid this could easily remain unfixed forever . Lol
HTML code is On
PT Shortcut for cascading outputs no working anymore in PT 2020.9.1 master faders bsteeve Post - Surround - Video 2 10-26-2020 12:11 PM
Help!! - Protools 2020.3 Event Operations not working at all MissLoriV Pro Tools 2020 1 04-02-2020 10:34 PM
Protools 10 audio outputs stopped working for no apparent reason Cryos Pro Tools 10 6 04-03-2012 04:13 PM
How do I create master outputs in Protools LE 7.4.2 Sean L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-27-2008 10:31 AM
Cascading direct outputs in mixer? D Pinder Tips & Tricks 5 03-17-2000 03:41 PM
