Re: Search issues in the PT 11 "improved" Workspace
Cool, they speed up the search but obstructed the searching..
http://felixrost.de |
I just voted on the Ideascale page. Logical AND makes the most sense when searching, anyway you look at it.
Chris |
Workspace in 11 is so shockingly bad we bought Soundminer Licenses
It's amazing. A much more logical search system (like PT10), and the ability to highlight, audition, and then drag the specific bit of a long Sound Effect that you need into your timeline without bringing in the whole thing, making sure you haven't dragged it onto of a file, then trimming and placing it. |
I use Soundminer for sound effects cutting, but I also use the Workspace quite a lot for other things, especially recycling sounds from other reels. It's not practical for me to scan every reel into a Soundminer database and try to keep it up to date when the Workspace is already doing that perfectly.
Although Soundminer now has a waveform preview column, the one in PT is way faster loading and easier to use visually (in Soundminer using waveform view screws up your layout and takes way longer to load). I can see hundreds of sounds at a glance and get a sense of which ones to audition without having to read through all the descriptions. But now the search function is essentially broken which is a huge bummer.
Pascal Garneau | IMDb |
Regarding Pro Tools and Soundminer, I've compared PT 11.3 to 11.0.2 to 10.3.9 to Soundminer. I have to say that PT 11.0.2 casts too narrow a net in the search. PT 11.3 casts too wide a net. Comparing PT 10 to Soundminer, PT10 outperforms the Soundminer search engine. It would be very nice to get PT 11 to perform simple (and advanced) Boolean search commands (similar to PT10 in the simple search aspect).
To start, simply reverting the search logic in PT 11 back to the way PT 10 worked would be great. Then, adding the AND and OR logic would be great. Lastly, adding Advanced Boolean search logic would make the workspace such a powerful search engine. |
IdeaScale status has changed from "Active" to "In Review" last week.
But yesterday changed to "Active"... Why? |
Regards, JC |
Field recorder guide track "select areas to search" doesn´t work | kwassen | Post - Surround - Video | 6 | 04-12-2017 11:53 PM |
"Improved" Field Recorder Functionality in PT10 | simonchase | Post - Surround - Video | 5 | 03-21-2012 06:00 PM |
BRAND NEWBIE HERE: 1st error message - couldn't locate info in a "search" | csrMark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 02-16-2010 02:41 PM |
MIX review of HD: " vastly improved audio" | knewbee | Pro Tools TDM Systems (Mac) | 17 | 02-06-2002 12:56 AM |
I can't "Back" to Search results, after reading a message?? | el biciclista | General Discussion | 0 | 06-15-2001 04:57 PM |
