Old 01-12-2007, 07:45 PM
rckandorroll rckandorroll is offline
Default Breathy vocals and vocals in general
Hey everyone, I'm new to protools and i've been trying to record vocals with sort of a breathy almost whispery quality, sort of like chino of the deftones if you know them. i'm not playing metal, mostly ambient type stuff but i can't get a level right without it clipping or just sounding really [bleep]. what are some good ways to maximize the breath. im using an MBox 2 by the way.
also, does anyone have any tips for recording vocals in general? everyone always says "make sure you use compression" well i do but it doesnt seem to affect the overall sound at all so maybe i'm doing it wrong.
thanks!
Old 01-13-2007, 11:47 AM
Naagzh Naagzh is offline
Default Re: Breathy vocals and vocals in general
Tape a pencil to your mic vertically, directly in front of the diaphragm. This will deflect some of the incoming air to the sides and decrease the "rumble" (proximity effect) when you breathe heavily. Use a pop-screen as well.
Use the Comp/Dyn III plug-in. The vocal levelor preset is a good place to start.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 01-13-2007, 01:01 PM
I believe in the Deftones stuff there's a filter of some kind on the vocals. You might try Izotope Vinyl or a telephone-voice type of effect. Or try Amplitube or other distortion plug.
Compression on vocals should be used to even out the quiet and loud parts. You shouldn't "hear" the compressor working, unless you're going for a specific colour or pumping sound.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 01-16-2007, 11:59 AM
mixx mixx is offline
squash with a compressor for breathy after the fact
Old 01-25-2007, 02:09 PM
therm therm is offline
Default Re: How To GetBreathy vocals and vocals in general
I tried to post this once already, but it didn't seem to come through. Here it comes, again
1) Buy 'Russ Long's Guide to Nashvill Recording' for $30/$40. Great investment and it covers a lot of this stuff.
2) Use a high-quality mic like a Neumann U87 or a ribbon, through a preamp, to a compressor (I use a crappy Behringer Composer Pro & it works great) into PT.
3) Use a stocking or a pop-filter (esp on a cheap mic like a SM57).
4) Adjust the ratio to 2:1 or 3:1, set the attack & release to fast; bring up the threshold until you're getting 1-2 DB Gain reduction on meters as you're singing.
5) If you want a better SNR (signal-to-noise-ratio) go back and bring up the expander threshold (at a ratio of 2:1) until you get rid of the ambient noise (you can see this on the PT meters when you're i n Record-mode).
Works great on my projects.
HTH,
therm
Old 01-30-2007, 10:10 PM
Deafeye Deafeye is offline
Double, triple, and quadruple breath takes. This makes them louder, richer, and if you do it right, you can't even tell they're doubled, cuz you're whispering. And you don't need a Neumann U87, a pencil, or Izotope.
It works, trust me. (also try putting a layer of whisper takes above the main vocal that is being sung, that sounds cool...) Now all you would have to do is blend it to taste.
Cheers,
~Ben~
Breathy vocals and vocals in general rckandorroll Tips & Tricks 3 01-30-2007 10:13 PM
Compression for breathy vocals reverieman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-01-2006 02:42 AM
hey rap vocal question (I guess vocals in general) craiz730 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-22-2003 05:03 PM
Breathy Vocals or Jars of Clay. Princeton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-28-2002 09:30 PM
Any tips on blending old vocals with new vocals? Somebody Pro Tools TDM Systems (Mac) 5 06-07-2000 08:38 AM
