[SOLVED]PC-Copy Programmed SoftKeys Between Apps
I have been programming my MC Control and Transport to work with Sony Vegas since it is not Eucon aware it has to be done manually.
Now that I have done this I am also doing the same for Sound Forge10, but most of the Key Commands are identical. Instead of re programming every soft key again, is there a way to use the Vegas file as a template or starting point for SoundForge. I tried finding the Vegas .xml file and renaming it to the sound forge name(Forge100.xml), but that did not work. I also could not figure out a way to copy and paste programmed soft keys between app sets. Any one know if this is possible?
PC-Windows10 64bit - i7-4920 - 32gb ram - RME9632 -Nuendo 8 - ProTools 9 - MC Control - Mix - Transport MAC- OSX - 10.10.5 - MOTU828MKII - ProTools9 Last edited by johngar; 04-22-2011 at 03:24 PM. Reason: solved-edited title |
SOLVED PC-Copy Programmed SoftKeys Between Apps
I figured out how to do this.
First thing is , you need to exit EuControl, and turn off any controllers. Then find the .XML file that you want to copy or use as a template for another app. Then make copies and put them in another folder to back them up. In my case I am using the Vegas100.xml file found in: C:\Users\XXXXXX\AppData\Roaming\Euphonix\UserSets\ MC2User\MC_USER_SET__Root, (where XXXXXX is your user name). This the file I am copying from. Open this .xml file in Notepad or the like, copy what you need to and then paste it in the file you want those key commands to show up in. In my case Forge100.xml. Re start EuControl and turn on the controlers. Now all the softkeys and custom jog wheel commands I spent time programming for Vegas now show up for SoundForge, without having do re-program the same commands. Thanks for playing.
PC-Windows10 64bit - i7-4920 - 32gb ram - RME9632 -Nuendo 8 - ProTools 9 - MC Control - Mix - Transport MAC- OSX - 10.10.5 - MOTU828MKII - ProTools9 |
Re: PC-Copy Programmed SoftKeys Between Apps
That's great! Thanks for being so resourceful and also for sharing your solution.
Some of my older settings you can download here (they are not fully updated, but if someone can save some time due to it, you're welcome...)
http://www.freewebtown.com/ba_swing_..._Euphonix.html
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
Copy softkeys in EuControl ? | HansH | Artist Series | 7 | 05-07-2012 01:35 PM |
Copy, cut & paste in the softkeys editor please! | Oblique | Artist Series | 8 | 07-21-2010 06:15 PM |
Programmed Drums? | Orange Worker | Tips & Tricks | 8 | 11-30-2005 02:28 PM |
Overheads - Emulating with programmed drums | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-03-2005 07:47 AM |
Programmed Drums Feel, well... Programmed | rockwithrespect | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-03-2005 07:18 AM |
