#31
Re: Import session data - access violation
The issue you are describing has sometimes occured on my setup, but what I have is different and definitely a repeatable bug introduced with 8.1. Trying to import an aux-track from a project that has different I/O-Settings than the project you try to import to, leads to an error-message "Could not complete your request because An access violation has occured, while translating tracks". After that you are not able to save the project, sometimes PT hangs... I think it has something to do with the new I/O-Setup introduced in 8.1 The only workaround is to deactivate input / output / send-settings in the import settings
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
#32
Here also; really difficult not being able to import bus paths.
I'm glad to see someone from Avid looking at this thread, though? Chas PT 8.1.1 OS 10.6.8 HD Accel 2
http://www.cdbaby.com/cd/chaswilliams |
#33
i did not have nor take the time to read this entire thread so i don't know if this is applicable or not but i had a session crash
access violation...could not save and it told me i had bad wrong characters i had used a / or - in the name of my session maybe even on a file name PT doesn't like some characters...even in the mac version which i use after i changed the name (got rid of those characters --// all was cool
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
#34
I got you studioJimi. I think this is pretty much a PT 8.1 thing that came with the new I/O set up?
Thanks, Chas
#35
Ok I have been having this issue and its been driving me nuts!! Info here is correct!! Make sure all of your busses and AD/DA I/O are named the same between the 2 sessions and everything imports perfectly fine. I thought it was the aux tracks causing the problem and it was they just had different i/o path names and once I changed the names of the aux busses i/o paths to be the same I have had zero issues. PTHD 8.1.1
Can't Import Elastic Audio Tracks (Access Violation) | jrwiles1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-28-2011 04:05 PM |
Import Audio - Access Violation then Crash | riffshack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-12-2010 09:41 AM |
Access Violation - RTTI data | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-25-2010 12:50 PM |
cant import data - no access privileges?? | digidesigner | Pro Tools TDM Systems (Mac) | 1 | 11-20-2008 07:36 AM |
Access Violation on just one session - please help | manilarice | Pro Tools M-Powered (Win) | 3 | 09-11-2007 05:33 AM |
