Old 11-17-2019, 04:18 PM
js_nyc js_nyc is offline
Default Error: Plug-ins not enabled- not 64bit compatible
Hello all,
Running PT HD 12.6.1 and 10.3.10
Mac OS 10.8.5
Everything was running smoothly in both PT 10 and PT12, until recent plug-in error- saying they are not 64 bit compatible.
Saw many other threads for newer versions, but no real solution. Someone suggested a problem with one component of Izotope Ozone, so I took it out of the plug-ins folder; restarted PT with same issue.
Just wanted to see if anyone else had solved this annoying problem. Other posts say to upgrade to High Sierra, but I still need PT10 on my computer for working with an ongoing client.
Please help if you can. Thanks.
js_nyc
15" Macbook Pro (Mid 2012) 2.3 GHz Intel Core i7
16G Memory
PT 10.3.11/ 12.5.2
003 Rack
OSX 10.8.5
ProToolsConsultant.com
Old 11-17-2019, 04:54 PM
Southsidemusic's Avatar
Default Re: Error: Plug-ins not enabled- not 64bit compatible
Still happens in HS with Sly-Fi plugins and ”I Wish” plugin which are all 64bit AAX64 but still PT says they aren’t!! Updated ILM and PT2019.10 Ultimate ...
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-17-2019, 06:35 PM
Wow- thanks for the reply. Still a weird situation, since we know that the plug-ins would not work in PT12 if they weren't 64 bit. And the disabled plug-ins are not third party- they are AVID's own!
js_nyc
16G Memory
PT 10.3.11/ 12.5.2
003 Rack
OSX 10.8.5
Old 11-18-2019, 09:15 AM
The Weed's Avatar
The Weed The Weed is offline
Did you update an iPhone or iPad to iOS 13 and plug it into your computer?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-19-2019, 08:25 AM
Good call, but no updating any external devices.
js_nyc
16G Memory
PT 10.3.11/ 12.5.2
003 Rack
OSX 10.8.5
Old 11-19-2019, 01:22 PM
Nothing connected here either as we dont use ipads on these Macs, we do on a few other ones but those are still High Sierra. These Mac Pro's Only used for PT and Live10. No iphones or ipads updated on any of these nor connected but thanks for that heads up! Many members have asked about this so hood call to involve that bit on the thread.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
is 10.3.10 compatible with Reason8 (64bit) [email protected] Pro Tools 10 3 07-22-2015 03:11 PM
Digi 003R & Win7 64bit-- is it compatible? edwincalle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-10-2013 08:07 AM
Plug-ins must be AAX 64bit for PT11, not just AAX? yeloop Pro Tools 11 1 06-25-2013 12:13 AM
[Bug: PTHD10] Plug-in settings paste error "Not Compatible" jeremiahmoore Post - Surround - Video 4 02-22-2012 10:29 AM
Error after installing the Bombfactory Plug-ins......are they XP compatible? seanhupe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-11-2002 07:55 PM
