Old 09-03-2019, 09:15 PM
nandan21 nandan21 is offline
Default DSP MixEngine Cards Issue.
My Venue SC48 on startup shows following Dialogue box:
Confirm MixEngine Firmware Update
The firmware on two DSP MixEngine cards need to be updated.
The update procedure takes approximately 16 minutes, and can not be interrupted once started. The logo screen is displayed while the update is in process. Once the update is complete, the system will automatically shutdown.
Power the system back on to resume operations.
Option of UPDATE is there.
As soon as I try to press 'Update' the console shuts down and doesn't boot up.
I tried disconneting the cards and refitted them, but still the problem persists. Any solution? How is it possible that both cards stopped functioning/ died simulteneously?
Old 09-24-2019, 03:37 PM
RyanJ's Avatar
RyanJ RyanJ is offline
Default Re: DSP MixEngine Cards Issue.
it's more likely that one card failed, but since they're daisy chained it is showing as if two did. Have you called support?
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Old 09-25-2019, 03:20 AM
I swapped Mix engine card position and thus TDM cable ports used on the card also changed. It started working fine. Might be some oxidation issue with TDM cable port or contact issue. Does not know exactly why...
Issue with 2 hdx cards on FOH rack. bblackstone VENUE Live Sound Systems 0 05-29-2013 09:38 PM
Mbox Pro (3rd gen) crash issue : What are some good firewire PCIE cards? HussainA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2012 07:28 AM
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 02:39 PM
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in phatbeatstudio Pro Tools TDM Systems (Mac) 6 10-15-2011 11:35 PM
HD cards compatibility issue Mercurix Pro Tools TDM Systems (Win) 2 11-13-2007 03:28 PM
