Old 02-08-2018, 11:17 AM
richardblythe richardblythe is offline
Default Re: Pro Tools 2018.1 low latency monitoring issues
Originally Posted by Oufti View Post
Having the same issue here on PT2018/iMac 2012-HighSierra/Apollo 8p. The only turnaround I found is to open the Playback engine Dialog window, then click OK and everything is back to normal, as long as I record on the same track (the issue comes back when arming a new track for recording).
I too am having the same issue with LLM not working. It worked perfectly until upgrading to 2018.1.0. The doubling while recording is driving me crazy! Oufti, I'll try what you suggested and see if it works for me.
Old 02-08-2018, 11:38 AM
ZEUSS ZEUSS is offline
I am getting some weirdness with A doubling type of sound with almost like a distorted filter of my main outputs on some sessions. Once I change the playback engine to another value, it fixes the issue. This started in version 2018.1
Anyone have those symptoms? This is after all standard troubleshooting like resetting prefs etc.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 02-09-2018, 11:28 PM
michaelevancoe michaelevancoe is offline
Hey all. Having same issues with LLM on PT 2018.1. Seems the method of opening playback engine temporarily fixes issue until a new track is record enabled.
Hopefully this gets fixed soon by Avid! 🙏
Old 02-10-2018, 08:20 AM
john1192 john1192 is offline
i tested this earlier in this thread - post #6 ... can someone take a look and let me know if i missed something while trying to repro this please ????
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-10-2018, 01:44 PM
@john1192 the error only happens while in QuickPunch for me
  #16
Old 02-22-2018, 06:41 AM
Oufti Oufti is offline
I tried that but it got worse: with new prefs I have the double signal permanently...
Hopefully I was able to restore the previous prefs (didn't empty the trash) and got back to the previous case
  #17
Old 02-26-2018, 01:07 AM
iamlark iamlark is offline
I'm using an Apollo Twin (monitoring routed through apollo console) and ran into this issue and eventually tracked down something here -
Seems the problem appears for me when I change the AFL/PFL audition path to anything other than the default MON L/R. If it's set to any of the virtual channels, LLM stops working correctly, but will be happy again if I set AFL back to MON. Doesn't seem to matter for me what any other the other paths are set to in the I/O, just the AFL.
Edit - I should add that I was not using AFL mode at the time. I was set to SIP mode, but only changed the output audition routing.
  #18
Old 02-27-2018, 05:24 AM
Ok, still been working on this.
To get any sort of function whatsoever from LLM, you must have "Mute Record-Armed Tracks while Stopped" checked. Then, open playback engine, close playback engine. LLM works correctly until you disarm that track. It won't work correctly until you do the playback engine trick again.
With "Mute Record-Armed Tracks while Stopped" unchecked, LLM has no effect whatsoever. Sends are marked as bypass but the audio still flows, in stop or play (record enabled). Playback engine trick doesn't fix in this case.
I tried out changing the AFL/PFL and audition paths in I/O, seems to have no effect.
Gear I'm using:
MBPro 2017
Antelope Orion Studio Rev. 2017
Protools 2018.1
Avid support contacted me back... apparently they tested this with some Avid gear and couldn't reproduce the issue... kinda seems like they didn't really try to test thoroughly .
This is SO frustrating. Have also tried on different systems, even tried PT12. nothing different
  #19
Old 02-27-2018, 06:45 AM
zion zion is offline
It's working fine on my system. Has been since day one.
  #20
Old 02-27-2018, 06:47 AM
I highly doubt this is a hardware issue... just seems to be a bug in the PT software...
However the fact that installing PT12 didn’t fix it has me wondering...
low latency monitoring in Pro Tools 11 - IS THERE AN ANSWER ....? Zee&Eli Pro Tools 11 22 03-10-2017 07:23 AM
Low Latency Monitoring in Standard Pro Tools 9? Dizzi45Z Pro Tools 9 20 02-06-2012 08:55 PM
Pro Tools 9.0.5 - Low Latency Monitoring problem still persists xazqe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-02-2011 08:54 AM
Monitoring Latency issues 001 and Pro-Tools 6.4 LE eastwood1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 08-30-2006 01:04 AM
Pro Tools Free OS 9 monitoring latency - help!! sunlikeblood Digidesign Hardware & Software 2 12-29-2003 04:56 PM
