Old 12-24-2014, 08:44 PM
ArKay99 ArKay99 is offline
Default -9171 and -9172 errors Pro Tools 11 | HD
I've seen the sticky, but that relates to PT 10 HD. I run both 10 and 11 HD and get these errors in both. I'm running Barracuda (7200 rpm drives) and have feeling they are a tad slow... or is it the Mac Pro SATA bus? Has anyone got this beat? I'm thinking of trying an SSD and if that works, changing to a Raptor (15k rpm's)... Any help or insight is helpful.
BUG REPORT: http://protools.ideascale.com/a/dtd/153575-3779
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
Old 12-31-2014, 05:08 PM
Default Re: -9171 and -9172 errors Pro Tools 11 | HD
488 views and no comments? So, I'm the only one? If this has been solved, I'd like to know the answer...
Old 01-04-2015, 12:54 PM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
me too. I don't think it's any one thing though…
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 01-04-2015, 02:30 PM
Fidelis Fidelis is offline
Never had this with HDX... Sorry, can't help you.
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 01-04-2015, 03:15 PM
Fidelis, you've never had the 917x errors running sessions with PT11x and HDx card? What kind of sessions do you normally work on? Do you use native plugins? Are they mostly mixing or tracking sessions? Just curious as I've thought these errors are fairly common.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 01-05-2015, 03:33 PM
Thanks for at least replying Fidelis. A couple of questions if I may. Do you use any VI's that require samples? And if so, do you keep them on the system drive or a separate drive for samples only. I think I will try that...I just bought a couple of SSD's.
Old 01-05-2015, 08:01 PM
glasswing glasswing is offline
I installed two SSDs in my 2012 Mac Pro a couple days ago (32 gigs RAM) and IT SMOKES! PCI 480 gig HD for clean install Mountain Lion OS and 480 Gig in a hard drive bay. No more warnings about anything being too slow or needing to raise the buffer size etc. I'm running a fair ton of VI's. Plus, the video looks terrific.
I got my SSDs at Other World Computing.
I think your troubles might be over.
Richard
www.glasswing.com
Mac Studio Ultra / 128 RAM/2TB HD / Avid HDX Chassis / 2 X Sonnet Echo Dual NVMe Thunderbolt Docks w Samsung 970 EVO Plus (6TB) / Avid C24 / Avid 16X16 I/O Analog / Lynx Aurora 16/16 1/O Analog / Dangerous 2 Bus / Benchmark ADC1
www.glasswing.com
www.richardsales.com
Old 01-05-2015, 09:34 PM
glasswing did you go the Electra or the Extreme route with your drives from OWC?
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 01-06-2015, 07:15 AM
No VIs here. Just audio tracks. Most at 88.2 or 96khz. From 20 to 100 tracks... Never had this errors. Just mixing here.
Must say that I mix on a console, so not to many plugins. But I do use some!
Wondering if SSD really speeds the system up!
Old 01-06-2015, 07:17 AM
Oh, mostly native plugins...
-9171 and -9172 errors with Pro Tools HD 10.3 on HDX Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 519 03-08-2017 10:11 PM
Still getting -9171 and -9172 errors and confused about this 'upgrade' ArKay99 Pro Tools 11 0 12-23-2014 12:23 PM
Pro Tools 10.3 9171 and 9172 Errors Tops3b Pro Tools HDX & HD Native Systems (Mac) 20 07-14-2013 03:11 PM
UAD triggering 9171, 9172 errors? xq3js macOS 7 03-22-2013 11:47 PM
10.3.3 Major Fail....9171, 9172 and 9129 Errors Tops3b Pro Tools HDX & HD Native Systems (Mac) 3 12-21-2012 07:21 PM
