Old 03-10-2014, 10:12 AM
Actionmusic Actionmusic is offline
Default Re: HDX Latency
Note i've had tracking weirdness when ADC is off but the ADC delay is still anything other than OFF (in PT10).
Also drag the track you are recording on to the top of the session, see if you have same problems - i have had latency on sessions on HDX and also native (with low latency monitoring) where this has helped.... crazy I know
Old 03-10-2014, 10:57 AM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
I was able to duplicate the problem in PT10, so I think it's a hardware issue. Different version, different system drive, same issue.
I'll try dragging the track to the top of the session, 'cause if that works, it might point to something (but what?). It's not optimal, of course.
Old 03-10-2014, 11:14 AM
TOM@METRO's Avatar
I have this HDX/ADC issue as well.
I have also noticed it if I duplicate a track and then try to record on it.
Restarting PT usually solves it.
There are also times when the pre-roll section is very out of sync but it's fine in record.
I have pushed this up the chain of command.
I'm still trying to sort out a an acceptable workaround.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-10-2014, 12:56 PM
So Tom, someone "in there" knows about this?
(Do they happen to know where the missing 777 is too?)
Old 03-10-2014, 02:57 PM
This is also a part of my general workflow. I've never been able to create a session where I can reproduce this problem every time annoyingly. It's generally a) big mix or VI/tracking sessions with overdubs b) not having delay compensation set to off on the Engine AND the delay comp tick ie: recording into an exisiting mix session c) duping my vocalling (empty) track for next takes...
EDIT: btw I really think there should be some easy access bug reporting email/form that doesn't involve ideascale or Avid support cases. and yes I submit all my Avid crash data via Pt11... there's plenty of that as well.
  #16
Old 03-11-2014, 06:58 AM
Meccanizm Meccanizm is offline
Am Having Latency Issues two
  #17
Old 03-12-2014, 05:43 AM
loosestones loosestones is offline
I have a HDX2 system and am having these issues too, mostly when doing what an above poster mentioned (duplicating existing audio tracks sans the audio to record on) For example, I'll have 2 tracks setup to record some rhythm guitars on the left side, then duplicate the tracks to record the right side.
Closing the session, then reopening fixes the issue for me, but it's such an annoying issue (that I did not have on my old TDM system)
Any word on this from the AVID guys?
HDX|2
Matt
Loose Stones Studios
  #18
Old 03-15-2014, 07:43 AM
Kaneepa Kaneepa is offline
Same problem in my two different studios .. One HDX2 and one HDX based.
I had the same bug on HD6 too before upgrading..
Sometimes in complex sessions while recording a new track, latency goes crazy high .. My workaround is pressing two times the green input button .
This usually temporarily solves the problem and resets back the latency on the record track to zero ..Usually though a couple of takes later bug will reappear...
Please Avid investigate !
  #19
Old 03-15-2014, 09:28 AM
JFreak's Avatar
JFreak JFreak is online now
First of all, check your session setup window. It will say how many samples of latency your system has. IF it's too big a number, you are using some (perhaps just one) plugin that causes massive amount of latency that needs to be compensated 'cause I assume you have delay compensation activated.
Second, take a look at what your mixer window can show you. There's delay compensation option as well. This will show you which track causes you most trouble. Inactivate plugins one by one and you will know which one is your problem.
I'm 99% sure this advise will help you get things going...
Janne
  #20
Old 03-16-2014, 04:17 AM
Nope, session latency is fairly low on all my sessions where this is happening?
(at most (1500ish) any other ideas?
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Piano VI's- Latency Latency!! MARVINBASS Virtual Instruments 5 04-27-2006 01:09 AM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
