Old 11-01-2013, 06:15 PM
Touchwood Studios Touchwood Studios is offline
Default Offline Multi-Out Bounce broken
Offline Bounce 16 stereo outs ( tried 8 as well )
opened session with all plug-ins deactivated - only had VEP 5 and 6 DSP plug-ins
activated - VEP 5 instruments routed to 16 stereo inputs.
Offline (16 Outs) bounce broken crashes every time
Realtime bounce works
Mac Pro
32 GB RAM
HDX 2
96K sessions
10.8.6
HD 11.0.2
OS 10.8.4
Old 11-01-2013, 10:57 PM
mrtomcat mrtomcat is offline
Default Re: Offline Multi-Out Bounce broken
Please excuse my ignorance but how do you do a multi out bounce to begin with???
Old 11-02-2013, 04:20 AM
Drew Mazurek's Avatar
This is a PTHD only feature.
http://www.avidblogs.com/pro-tools-1...ve-processing/
www.drewmazurek.com
Old 11-02-2013, 04:21 AM
Mac Pro
32 GB RAM
HDX 2
96K sessions
10.8.6
HD 11.0.2
OS 10.8.4
Does it work with NO plugs at all, just audio?
www.drewmazurek.com
Old 11-02-2013, 07:30 PM
I am trying to bounce a Superior and Slate Drums through VEP 5 so if I bypass the plug-ins I get no audio.
Old 11-03-2013, 04:37 AM
DetroitT's Avatar
DetroitT DetroitT is offline
I do 12 at once from superior-AAX with no issue, Import after/offline.
All output splits in SD and track routing for stereo monitoring and discrete outputting saved as template.
Much better than the SD render method!
Old 11-03-2013, 04:58 AM
I was trying to isolate if it was just a PT issue, or possibly involving VEP etc. As DetroitT confirms, it's not PT and/or SD specifically so you have to look elsewhere.
Does it work with VEP and other instruments?
www.drewmazurek.com
Offline bounce bug ? deardaddy Pro Tools 11 20 12-28-2016 02:43 PM
Offline Bounce maxsuperpower Pro Tools 11 20 12-09-2013 11:06 AM
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 09:29 PM
Offline Bounce DonaldM Pro Tools 11 6 11-17-2013 08:56 PM
Offline Bounce? bboiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-12-2005 02:38 PM
