I would try do the move aside plugin files test and see if you can quickly find a problem.
Buy OTOH I would never trust a OS X migration if you moved lots of stuff that way I'd be prepared to cut my losses early, stop doing too much debugging and just reinstall everything from scratch. And along the way, whatever you do you need to check you have up to date plugins. And who knows if this is really the cause, but I would certainly suspect this as a possible problem. On power management, I would not let the drives ever spin down, disk cache or not. Run through and check all optimizations are applied. By 16/16 you mean you have Avid HD interfaces or Apogee 16x16? Darryl |
And I did not see a UAD mentioned. Definitely try without that installed. (I'd even move aside the plugins just to
be paranoid). |
Re: PT just keeps stopping - help please
Ok
16/16 is Avid. |
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
#16
My OWC 3G SSD drive does not support Trim, and I formatted with Disk Util. |
#17
Just to recap... From where I am now I will do this: 1. Uninstall protools 2. Delete all RTAS + AAX plugs 3. Install protools 4. Install all plugins ok? All other apps and settings on my system drive are migrated, but thats not of our concern, right? Note: OS 10.8.1 has been installed on the clean SSD. Boe |
#18
New status:
Deleted protools and all plugs clean. Installed PT 10.3.0 from scratch. ONLY Avid plugs. Rapaired disk permissons. Launched protools. Get the same -9171 errors. Was able to strip the current session down to 1 mono track with no plugs and get the samme error when recording. With these audio setting: HW buffer: 512, 11 processors, CPU limit 85, 256 voices, no delay comp, cache normal. Same thing with cache 2gb. Happens a bit less with buffer at 1024, but still a lot. SO - I create a new blank session with one mono track. Same settings - and the errors don't come anymore. ODD. Don't quite know what to make of it. Will test more. |
#19
Did you take the uad card out of your Mac? Also what pcie slots are your HDX cards installed in?
#20
PCI1 - ATI Radeon HD 5770 (screencard) PCI2 - HDX PCI3 - HDX PCI4 - UAD No, did not take the UAD card out. Should I try that? Thanks, Boe |
Pro Tools 10.3 9171 and 9172 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 20 | 07-14-2013 03:11 PM |
-9171 and -9172 errors constant...Sandra attached | wrachilla | Windows | 12 | 05-09-2013 09:19 AM |
UAD triggering 9171, 9172 errors? | xq3js | macOS | 7 | 03-22-2013 11:47 PM |
Dae errors -9171 after installing 10.3.3 | TCM | Pro Tools HDX & HD Native Systems (Win) | 3 | 02-06-2013 10:18 AM |
10.3.3 Major Fail....9171, 9172 and 9129 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-21-2012 07:21 PM |
