Vacuum patch gets shorter decay time at 96kHz session than 192kHz session
I just made a Vacuum patch yesterday and noticed something strange happening with the decay going from 192kHz to 96kHz.
The decay time in the patch I made is considerably shorter for a 96kHz session compared to a 192kHz session. I will post the name of the factory patch I tweaked with it's settings when I get home after work. Hopefully this can be replicated by others. |
Re: Vacuum patch gets shorter decay time at 96kHz session than 192kHz session
Here are that the patches I have problems with.
Try opening in both a 192k session and then in a 96k session. http://dillner.net/vacuum/ |
Anyone had the chance to try this ?
Pretty sure I can do some testing for you tomorrow, but I'm still on 7.4.2.
Drop the .dpm files into the Plug-Ins folder Stig. Creative Collection should work in Pro Tools 7.4.x. I'd run the test but my I/O won't go up to 192kHz.
Aaron Mulqueen - 001 HD Native |
I know, Aaron. I'm using all the AIR plugins that came with PT 8 on my rig. I just thought that since OP is on 9.x.x it might be a useless test. Thanks.
Thanks/takk Stig.
Give it a shot anyway Stig as it might have gone under the radar.
Your wish is my command.
Can't test this for you. I forgot that the enclosure connector (AES/EBU) on my interface only support up to 96 kHz, and it's a major hassle for me to get behind the racks to re-wire the I/O's.
Sorry.
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Is my session 96khz ? | VictorC | Windows | 3 | 01-30-2014 11:23 AM |
192khz session not even an option. | Jakay | macOS | 18 | 09-18-2013 08:09 PM |
Convert 192kHz session to 96 | rososound | Pro Tools TDM Systems (Mac) | 3 | 03-17-2007 12:55 AM |
CoreAudio7.3 works above 96kHz? PT7.3 192kHz woes | Mauro371 | Pro Tools TDM Systems (Mac) | 1 | 12-15-2006 08:44 PM |
