Change tempo and make the audio move?
Hello,
I'd like to be able to change the tempo of my sequence so I can slow it down to work on detailed drum programming. Thing is when I change tempo the audio stays at the same spot on the grid. Is there a way to make the audio realign itself to produce the same timing but at a slower tempo? Thanks!
002, PTLE 5.3.2, A7V266-C, XP2100+ (1.7GHz), XP Home |
Re: Change tempo and make the audio move?
audio is on an absolute timescale. it won't move when you change the tempo map.
that would be a nice feature to have, though. sonar is great with that. working with loops is so easy in sonar.
i love my apple iPhone! |
d_matt,
There is a way to slow down/speed up audio tracks, but the audio doesn't always come out sounding as good as the original speed audio. Also, it works best if you're only changing the bpm slightly, like maybe +10 or -10 bpm from the original. To do this, you would highlight the Audio you want to change, and pull down the 'Time Compression/Expansion plugin. On the left of the plugin box, you'll see 'Source', which is the original bpm, and on the right you'll see 'Destination', where you'll put in the bpm you want it to be... then hit 'Process'. It may be worth a try, depending on what you're trying to do... -Roy
rh music |
you should try the SERATO Pitch n Time plugin, its great!!! the sound stay almost unalterable in quality... the time compression/expansion plugin sucks... [img]images/icons/grin.gif[/img]
How do I change the tempo and not have it move markers? | aasteveo | Tips & Tricks | 4 | 10-16-2019 01:20 PM |
Move the red diamond in the tempo bar in the edit window, only some tracks move | kingheartless | macOS | 2 | 02-21-2013 03:20 PM |
Make sliced audio move with tempo | Mike Greene | Pro Tools TDM Systems (Mac) | 5 | 08-18-2010 02:29 PM |
How change a bar to make it fit a different tempo? | beech | Tips & Tricks | 11 | 05-27-2002 04:27 AM |
Tempo change without pitch change for audio | layman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-16-2002 07:14 PM |
