Old 10-27-2002, 11:35 AM
remains remains is offline
Default recording guitar directly to 001????
Can I record guitar(electric) directly into 001 or do I have to have direct in box??
I have zoom 9050 effect for guitar.
Thanks!
Old 10-27-2002, 11:39 AM
vocalize vocalize is offline
Default Re: recording guitar directly to 001????
Hi remains!
Yes, you can go directly into the 001. What I usually do is plug directly into the 001 and add any additional effects that the song calls for.
For example, direct in-sans amp plug-Dverb-delay.
Gives me a nice sound for laying down ideas.
Good luck!
Old 10-27-2002, 02:17 PM
Originally posted by vocalize:
[QB]
QB]
<font size="2" face="Verdana, Arial">Thanx!!
What do you mean by that??
Old 10-27-2002, 02:45 PM
Lalaman Lalaman is offline
Use inputs 1 and / or 2 in the front of 001. They work better. The others are line.
Lalaman
Old 10-27-2002, 04:27 PM
Jonah Jonah is offline
I think he's referring to Sansamps' guitar preamp with Dverb and a bit of delay. I think ?? [img]images/icons/confused.gif[/img]
Old 10-27-2002, 04:34 PM
marbez marbez is offline
I had a bad experience recording guitars and bass through the 1/2 front inputs of the 001. The sound I get was weak and thin, no presence at all. Now I'm connecting my guitar and bass to my amp, and the preamp out to a line input of the 001. Then I hook the plugins, for example, the BF Sans Amp (coolest plugin I have) It do it to me. Any better idea?
mb
DIGI 001
ASUS CUSL2-C
PIII 1GHz (yes, I need an upgrade)
512 RAM
2xMAXTOR 40G
Old 10-27-2002, 07:46 PM
Hi remains!
What I meant was using either input 1 or 2 plugging your guitar directly into the Digi001. Then add a nice guitar processor (I use the Sans Amp) and some reverb, delay or whatever effect you need to fit the song. Works great for me!
Good luck. Hope this helps!
Old 10-27-2002, 08:56 PM
where02190 where02190 is offline
Inputs 1/2 are mic or +4dbu line level only, not designed for instrument level. Using inputs 3-8, in the hardware menuy, you can set the input level to instrument.
Otherwise run through a direct box or outboard instrument preamp with +4dbu balanced outs to utilize the front panel 1/2 inputs. You could also go into the 3-8 inputs set to +4dbu line level as well.
Best scenario is to use an instrument preamp with digital outs, and bypass the 001's so-so A-D converters.
Hope this is helpful.
Old 10-27-2002, 10:56 PM
Roy Howell Roy Howell is offline
remains,
I run directly from a guitar processor to 5/6 for electric, when not miking an amp.
You should be able to run your Zoom outputs directly to 3&4,5&6, or 7&8, and use any of it's settings you want.
~Roy
rh music
Old 10-27-2002, 11:57 PM
Good to learn again.
So mics to 1 & 2 and instruments to 3-8.
Another question: Would you raise the level of the 001 input for an instrument ( guitar efx ) or rather raise volume at the instrument ( I would be guessing the latter to be perferable ... ?)
Thanks
Lalaman
Recording directly in from Apogee Rosetta 200 via Optical? theaor macOS 2 03-10-2012 01:31 PM
recording guitar directly into 96io? nerd513 Pro Tools TDM Systems (Mac) 27 12-13-2011 07:18 PM
Recording Directly to Macbook Pro ionStorm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-04-2011 07:58 PM
Can't record guitar directly plugged to 003 Factory Ombor10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-28-2010 05:19 AM
Recording Bass Guitar directly into Digi 002? pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 07-03-2004 07:25 AM
